Re: Mechanical Fuel Pump
[Re: DusterKid]
#3071546
08/26/22 09:06 AM
08/26/22 09:06 AM
Posts: 4,715 Wichita
GY3
Wichita
Always used the Carter street/strip pump from Mancini.
[Re: GY3]
#3071547
08/26/22 09:08 AM
08/26/22 09:08 AM
Posts: 8,191 Plymouth, MI
Blusmbl
Plymouth, MI
I have had good luck with the Carter M6903. I think the M4862 is similar but runs at a higher pressure.
[Re: DusterKid]
#3071742
08/27/22 01:31 AM
08/27/22 01:31 AM
Posts: 43,355 Bend,OR USA
Cab_Burge
Which motor and how many carbs?
[Re: DusterKid]
#3071886
08/27/22 06:21 PM
08/27/22 06:21 PM
Cab_Burge
I would and have used the Carter Street hemi pump standard pressure (not the high pressure one ) version with three internal valves I used them on my old M.W. NHRA Stocker and on NHRA stocker street hemi motors also, works good last a long time. The best test I know of on testing fuel volume on drag cars is if you can jet the carb up rich enough to slow it down in the 1/4 mile you have more than enough fuel volume for that combination that day: scope :
