408 Magnum hydraulic roller break in oil #3070922
08/23/22 10:21 PM
08/23/22 10:21 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I'm just finishing up assembly on a stroked Magnum with stock rollers on a new cam and I was wondering if just standard 5-30 oil will work for break in. The only area I was concerned about was distributor drive gear wear. I applied Gibbs assembly lube to the gears and I think that should be good for start up. It is a Comp cast core not a billet cam so I'm using a stock type gear.
Thanks up
Gus beer
64 Plymouth Savoy
Dana 60
Re: 408 Magnum hydraulic roller break in oil [Re: fourgearsavoy] #3070991
08/24/22 08:15 AM
08/24/22 08:15 AM
an8sec70cuda Offline
You should be fine. I use VR1 race oil for pretty much everything...except for flat tappet break in.
CHIP
'06 GMC 2500HD LBZ Duramax
