Re: Any suggestion on setting points?
[Re: OA5599]
#307041
05/03/09 11:15 PM
05/03/09 11:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Car is breaking up above 6k rpm. New plugs gapped to .035, MSD 6A-L, points set to .017. I know I need to switch to electronic, but I have points for now. Any suggestion for setting my points? Wider? Narrower?
Any suggestions?
Most likely its the wimpy sping on the points... thats the reason they came up with dual point dist back then
[Re: Quicktree]
#307046
05/04/09 07:57 AM
05/04/09 07:57 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Any suggestion ? yea get rid of them. they went out 20 years ago.
yeah - set them in the trash can will ya!
[Re: Quicktree]
#307047
05/04/09 07:57 AM
05/04/09 07:57 AM
probably closer to 35 years ago. maybe you can find a factory electronic distributor to use cheap. anything would be better than points.
[Re: Dodgem]
#307049
05/04/09 10:29 AM
05/04/09 10:29 AM
Posts: 42 Summerville, SC
Gierhed
Summerville, SC
I'd be checking the shaft for bushing wear it's probably flopping around like a headless chicken.
I agree, I have chased that gremlin before.
[Re: Gierhed]
#307050
05/04/09 11:09 AM
05/04/09 11:09 AM
Posts: 302 Casa Grande,Arizona
DennisJ
super street
super street
Casa Grande,Arizona
I take the secondary spring off of a used set of points and mount it to the inside of the spring on the new set.That will stiffen the spring so you can rev above 7000rpm.
I don't know what everyones beef is with points. I have used about every ignition system there is over the last 45 years or so. If your stock ignition is in good shape, there isn't a performance gain with an electronic ignition system.
Dennis Jokela
I started out with nothing,and I still have most of it.
[Re: OA5599]
#307054
05/04/09 06:59 PM
05/04/09 06:59 PM
dartman366
Mt. Vernon, Ohio
I ran a mallory dual point dist with a MSD 7AL using only the primary set of points for years with out any problem's but your spring on your points is most likely your problem, and I even found that the gap really didn't change much, it's only a triggering system for the box and the dwell don't much matter eather, if you were running a conventional point/coil system then it would matter a lot.
[Re: dartman366]
#307056
05/04/09 07:24 PM
05/04/09 07:24 PM
that's pretty interesting.
