Any suggestion on setting points? #307039
05/03/09 10:31 PM
05/03/09 10:31 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Car is breaking up above 6k rpm. New plugs gapped to .035, MSD 6A-L, points set to .017. I know I need to switch to electronic, but I have points for now. Any suggestion for setting my points? Wider? Narrower?
Any suggestions?
Re: Any suggestion on setting points? [Re: OA5599] #307040
05/03/09 11:06 PM
05/03/09 11:06 PM
Points won't usually make a MSD miss unless that set has a real weak spring on the points, are you using a ballast resitor still? Is the coil and distributor wired like MSD says to do it? If not ry that, if it is check your spark plug wires for to high of resistance
Re: Any suggestion on setting points? [Re: OA5599] #307041
05/03/09 11:15 PM
05/03/09 11:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Any suggestions?
Most likely its the wimpy sping on the points... thats
the reason they came up with dual point dist back then
Re: Any suggestion on setting points? [Re: MR_P_BODY] #307042
05/04/09 07:15 AM
05/04/09 07:15 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Used to get them close with the gap and then adjust for dwell angle. It's been a while.
Re: Any suggestion on setting points? [Re: bobby66] #307043
05/04/09 07:38 AM
05/04/09 07:38 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
.015 to .017 or 28* to 32* dwell.Check your condenser,you may meed to add a larger condenser for the MSD,similar to the Mallory external large condenser.
Re: Any suggestion on setting points? [Re: B G Racing] #307044
05/04/09 07:51 AM
05/04/09 07:51 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Any suggestion ? yea get rid of them. they went out 20 years ago.
Re: Any suggestion on setting points? [Re: Quicktree] #307045
05/04/09 07:53 AM
05/04/09 07:53 AM
KYbywayof WV
Frito Offline
Frito  Offline
KYbywayof WV
My grandfather liked to set em at "a thin dime".
Re: Any suggestion on setting points? [Re: Quicktree] #307046
05/04/09 07:57 AM
05/04/09 07:57 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
yeah - set them in the trash can will ya!
Re: Any suggestion on setting points? [Re: Quicktree] #307047
05/04/09 07:57 AM
05/04/09 07:57 AM
probably closer to 35 years ago. maybe you can find a factory electronic distributor to use cheap. anything would be better than points.
Re: Any suggestion on setting points? #307048
05/04/09 08:40 AM
05/04/09 08:40 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I'd be checking the shaft for bushing wear it's probably flopping around like a headless chicken.
Re: Any suggestion on setting points? [Re: Dodgem] #307049
05/04/09 10:29 AM
05/04/09 10:29 AM
Summerville, SC
Gierhed Offline
Gierhed  Offline
Summerville, SC
I agree, I have chased that gremlin before.
Re: Any suggestion on setting points? [Re: Gierhed] #307050
05/04/09 11:09 AM
05/04/09 11:09 AM
Casa Grande,Arizona
DennisJ Offline
super street
DennisJ  Offline
super street
Casa Grande,Arizona
I take the secondary spring off of a used set of points and mount it to the inside of the spring on the new set.That will stiffen the spring so you can rev above 7000rpm.
I don't know what everyones beef is with points. I have used about every ignition system there is over the last 45 years or so. If your stock ignition is in good shape, there isn't a performance gain with an electronic ignition system.
Dennis Jokela
I started out with nothing,and I still have most of it.
Re: Any suggestion on setting points? [Re: DennisJ] #307051
05/04/09 11:15 AM
05/04/09 11:15 AM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
Use a matchbook cover. We did it for years.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: Any suggestion on setting points? [Re: Steve1118] #307052
05/04/09 12:11 PM
05/04/09 12:11 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
There's nothing wrong with a point system if it's in good shape, When i changed to the msd distributor and 6 al i didn't gain .010 in the quarter. That kinda p'd me off. Lot of money for no benefit.
Re: Any suggestion on setting points? [Re: rowin4] #307053
05/04/09 06:30 PM
05/04/09 06:30 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Gapped at .016 and it pulls hard without a miss to 6500 rpm, and that's as far as my 340 needs to go. Thanks for all of the good advice from all.
Re: Any suggestion on setting points? [Re: OA5599] #307054
05/04/09 06:59 PM
05/04/09 06:59 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I ran a mallory dual point dist with a MSD 7AL using only the primary set of points for years with out any problem's but your spring on your points is most likely your problem, and I even found that the gap really didn't change much, it's only a triggering system for the box and the dwell don't much matter eather, if you were running a conventional point/coil system then it would matter a lot.
Re: Any suggestion on setting points? [Re: Gierhed] #307055
05/04/09 07:21 PM
05/04/09 07:21 PM
organ
maximum entropy Offline
organ
you've chased a headless chicken?
Re: Any suggestion on setting points? [Re: dartman366] #307056
05/04/09 07:24 PM
05/04/09 07:24 PM
that's pretty interesting.
Re: Any suggestion on setting points? #307057
05/04/09 07:33 PM
05/04/09 07:33 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Man a junk yard elect dist cant be more than 20 bucks , lots of them around in the last 35 years
