Re: Locked out distributors Q
[Re: Wirenut]
#3070192
08/21/22 03:26 PM
08/21/22 03:26 PM
Posts: 2,080 CA
crackedback
CA
If there is no advance, you can time it at 100rpm or 10,000. should be the same, theoretically.
If you have a computer controlling timing with a locked out, that's different
[Re: crackedback]
#3070206
08/21/22 04:29 PM
08/21/22 04:29 PM
Posts: 630 Ct
Wirenut
Ct
I guess my thinking was that the requirement for advance would increase as rpm increases, at least to a point
[Re: jwb123]
#3070277
08/21/22 08:47 PM
08/21/22 08:47 PM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Set it at idle. Bring the RPM up to verify if you like, Should stay the same if there aren't a bunch of worn out parts in it. It will still move around some with a stock type set up. Lots of parts involved between the crank shaft and the distributor cap. Put a crank trigger on it and it will be rock steady.
[Re: CMcAllister]
#3070354
08/22/22 07:37 AM
08/22/22 07:37 AM
Posts: 630 Ct
Wirenut
Ct
Set it at idle. Bring the RPM up to verify if you like, Should stay the same if there aren't a bunch of worn out parts in it. It will still move around some with a stock type set up. Lots of parts involved between the crank shaft and the distributor cap. Put a crank trigger on it and it will be rock steady. Thank you
[Re: CMcAllister]
#3070362
08/22/22 08:39 AM
08/22/22 08:39 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
[Re: CMcAllister]
#3070371
08/22/22 09:11 AM
08/22/22 09:11 AM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Set it at idle. Bring the RPM up to verify if you like, Should stay the same if there aren't a bunch of worn out parts in it. It will still move around some with a stock type set up. Lots of parts involved between the crank shaft and the distributor cap. Put a crank trigger on it and it will be rock steady. This, and especially with a crank trigger.
"Any fool can know. The point is to understand"
- A. Einstein
