Re: 46RH help
[Re: 71Paisley]
#3069102
08/18/22 09:25 AM
08/18/22 09:25 AM
Posts: 75,136 A Banana Republic near you.
JohnRR
How do you have the TV cable setup ? I'm not a fan of blocking the accumulator in a street car , my 2000 ram 2500 cummins had that done and the shift ... 1-2 I think it was ... would rattle your fillings it was so harsh , granted it has a billet accumulator piston with a double seal ring arrangement, I took out the blocker and put the spring back.
I'm trying to figure out what you mean by "Torque convertor hub was worn at the index"
Is it a lockup convertor and you just don't use lockup ? What is the vehicle this is in ?
Re: 46RH help
[Re: 71Paisley]
#3069164
08/18/22 11:41 AM
08/18/22 11:41 AM
Posts: 26,051 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Accumulator shows 0-4psi . I never get over 4psi .
In what gear? There is no pressure at the accumulator in Park/Neutral. If reading is in gear, something's amiss.
Re: 46RH help
[Re: 71Paisley]
#3069234
08/18/22 02:25 PM
08/18/22 02:25 PM
John_Kunkel
Rio Linda, CA
You're saying the 0-4 psi accumulator reading is in all gears? If it's in all gears, you probably don't have the gauge hooked to the accumulator test port which is #3 or something is blocking the port.
Re: 46RH help
[Re: B1MAXX]
#3069326
08/18/22 06:40 PM
08/18/22 06:40 PM
Posts: 5,991 ohio
ruderunner
ohio
That converter hub and pump gear look destroyed to me. The ears on the gear are nearly 75% gone. They should be a much tighter fit on the converter. But the notches on the converter hub are hammered out too.
What's the rest of the pump look like?
Angry white pureblood male
Re: 46RH help
[Re: 71Paisley]
#3069450
08/19/22 09:30 AM
08/19/22 09:30 AM
Posts: 10 Patchogue NY
71Paisley
Patchogue NY
Thanks everyone for replys. I did a pressure test ( https://youtu.be/4LiNpfoTNBs ) and compared to another video I found online of a 47Re ( https://youtu.be/VwE64kuqx1Q ) . I don't think they are too different in that reguard. Comparing the videos I think my pressure test is satisfactory but what do I know ? I still haven't gotten into the valve body yet.
