Re: Playing cam swap on the dyno
[Re: HardcoreB]
#3068532
08/16/22 02:55 PM
08/16/22 02:55 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
That shirt seems fitting for the situation
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: dvw]
#3068554
08/16/22 04:09 PM
08/16/22 04:09 PM
Posts: 20,813 A collage of whims
topside
A collage of whims
They sure sound glorious at buzz-saw RPM, don't they ? Been 7500 on the Hemi and 8000 on the SB a bunch of times... But there's a mental picture of broken spendy stuff that would flash in my head before I shifted. Enough of that, and I curbed my enthusiasm by 500 RPM
[Re: greendart408]
#3068556
08/16/22 04:39 PM
08/16/22 04:39 PM
WHITEDART
bean town ....Ca
I try my best to fly that mother Mopar flag High
[Re: dvw]
#3068557
08/16/22 04:43 PM
08/16/22 04:43 PM
WHITEDART
bean town ....Ca
I like it. 7300 in my stuff makes me cringe. Doug you know how these little engines are we have to twist their arm behind their back until they squeal we actually will run another 5 to 600 RPM more in the car than we do on the dyno
[Re: LA360]
#3068680
08/16/22 10:37 PM
08/16/22 10:37 PM
WHITEDART
bean town ....Ca
Was it a single camshaft change you tested Shiloh? .. yes sir the new Wescott cam is amazing
[Re: WHITEDART]
#3068713
08/17/22 01:14 AM
08/17/22 01:14 AM
Posts: 6,145 Melbourne , Australia
LA360
Was it a single camshaft change you tested Shiloh? .. yes sir the new Wescott cam is amazing I hear Charlie can be a little prickly to deal with, but he really knows his stuff.
Alan Jones
[Re: LA360]
#3068742
08/17/22 07:35 AM
08/17/22 07:35 AM
Posts: 4,684 Wichita
GY3
Wichita
Sounds like all the horsepowers!
[Re: WHITEDART]
#3068752
08/17/22 08:21 AM
08/17/22 08:21 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
[Re: WHITEDART]
#3068774
08/17/22 09:41 AM
08/17/22 09:41 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
Was it a single camshaft change you tested Shiloh? .. yes sir the new Wescott cam is amazing Did he just grind a spec you provided? ….or did he consult also?
[Re: J_BODY]
#3068834
08/17/22 11:18 AM
08/17/22 11:18 AM
WHITEDART
bean town ....Ca
Was it a single camshaft change you tested Shiloh? .. yes sir the new Wescott cam is amazing Did he just grind a spec you provided? ….or did he consult also? the starting point was the camshaft that was in the motor the tweaks were made from there to get where we wanted to be
