SB Damper Question - Repairable or Paperweight? #3068224
08/15/22 04:59 PM
08/15/22 04:59 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
A friend has this small block damper in a box of miscellaneous parts. The front of the damper appeared to be okay until I flipped it over and discovered a section missing.
Is this damper now a paperweight?
Re: SB Damper Question - Repairable or Paperweight? [Re: vinnyd76] #3068228
08/15/22 05:05 PM
08/15/22 05:05 PM
md
mopars4ever Offline
mopars4ever  Offline
md
More like a door stopper.
Re: SB Damper Question - Repairable or Paperweight? [Re: mopars4ever] #3068253
08/15/22 07:20 PM
08/15/22 07:20 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
Not worth fixing.
Re: SB Damper Question - Repairable or Paperweight? [Re: mopars4ever] #3068306
08/15/22 09:48 PM
08/15/22 09:48 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
iagree Had a friend years ago that actually had the end of the crank snap off right at the front counterweight whistling beer
Re: SB Damper Question - Repairable or Paperweight? [Re: vinnyd76] #3068380
08/16/22 07:52 AM
08/16/22 07:52 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Scrap it
Re: SB Damper Question - Repairable or Paperweight? [Re: DusterKid] #3068402
08/16/22 09:37 AM
08/16/22 09:37 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I'd scrap it.
Rich H.
Esse Quam Videri
Re: SB Damper Question - Repairable or Paperweight? [Re: vinnyd76] #3068476
08/16/22 12:59 PM
08/16/22 12:59 PM
Are you feeling lucky whistling
AKA aside it might work and it might fail work tsk, I wouldn't take a chance twocents
Re: SB Damper Question - Repairable or Paperweight? [Re: Cab_Burge] #3068511
08/16/22 02:12 PM
08/16/22 02:12 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Thank you for the confirmations.
Re: SB Damper Question - Repairable or Paperweight? [Re: vinnyd76] #3068548
08/16/22 03:43 PM
08/16/22 03:43 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Re: SB Damper Question - Repairable or Paperweight? [Re: TJP] #3068732
08/17/22 06:14 AM
08/17/22 06:14 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Same thing with snap the crank, but it was driving a 6-71 blower.
Re: SB Damper Question - Repairable or Paperweight? [Re: vinnyd76] #3068978
08/17/22 08:18 PM
08/17/22 08:18 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
That small amount of missing material may not effect balance much, but the snout seems to have excessive oil seal wear grooves.
Scrap it & fine another, not that rare of item.
Re: SB Damper Question - Repairable or Paperweight? [Re: PhillyRag] #3069162
08/18/22 11:34 AM
08/18/22 11:34 AM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
junk
