B Body 8.75 into a C Body
#3068495
08/16/22 01:45 PM
08/16/22 01:45 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Have any of you guys ever swapped a B body housing into a C body?
I am considering pulling the drivetrain from my 02 Dakota to power my 77 Gran Fury. 5.2 magnum, A518, 4.30 suregrip.
The Dakota currently has a 67 B body rear I added when the original 8.25 gave up.
Just wondered if the B body rear fit the C body without getting into mini tubbing, etc.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: B Body 8.75 into a C Body
[Re: hp383]
#3068512
08/16/22 02:14 PM
08/16/22 02:14 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3068553
08/16/22 04:05 PM
08/16/22 04:05 PM
hp383
State of Confusion
The 77 Gran Fury is a C body
[Re: hp383]
#3068601
08/16/22 07:32 PM
08/16/22 07:32 PM
Posts: 1,179 Canada
demon
Canada
Your 67 B body rear end is one of the narrowest 8 3/4's, and your 77 has one of the widest rear tracks. In 1970 the C bodies had the rear track and spring spacing widened, and then in 71 on up, they added the rubber isolation which added even more bulk behind the brake backing plates. I doubt the 67 rear end would allow space for the rubber isolated business. I'd suggest dumping all the rubber isolation stuff, and using a 1970 C body rear end. It will bolt together, firm up the handling too. Just make sure you change the spring center pins to the normal early pins.
[Re: demon]
#3068633
08/16/22 08:49 PM
08/16/22 08:49 PM
hp383
State of Confusion
I will see what I can find. If nothing else I have a truck housing I can use and relocate perches and get narrowed if needed.
[Re: hp383]
#3071569
08/26/22 10:38 AM
08/26/22 10:38 AM
Posts: 2,255 IL
furious70
IL
I've got a C body 9.25" with a 4.10 sure grip I'd sell you very reasonably... PM me
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#3071581
08/26/22 11:31 AM
08/26/22 11:31 AM
Posts: 2,075 CA
crackedback
CA
Nice to see that horrible POS axle lengths chart still floating around. There is a better one in the tech archives that is correct
