Re: Alternate control Arm idea...
[Re: Lightning]
#306830
05/03/09 07:44 PM
05/03/09 07:44 PM
Posts: 27,483 So Cal
autoxcuda
So Cal
I hope I won't get flamed for this, but I'm out of options...
would a 2nd or 3rd gen Camaro upper control arm fit on a F/J/M-body?
how bout an A-body UCA??
You should be able to find one here used for pretty cheap. People used the spindles for disk brake conversions and they have to break the upper control arm ball joint in the process.
[Re: Lightning]
#306831
05/03/09 08:07 PM
05/03/09 08:07 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
How could a Camaro arm work on a Mopar ? They are a totally different suspension design and everything else... As mentioned, try a wanted add here or just look in the classifieds section and bet you'll be able to come up with something.
[Re: OzHemi]
#306833
05/03/09 08:14 PM
05/03/09 08:14 PM
Posts: 229 Augusta, GA
Lightning
Augusta, GA
well, I was looking at one of the control arms that Howe Racing makes for the Camaro and noticed it looked a bit close to the M-'s control arm.
[Re: TC@HP2]
#306836
05/03/09 08:52 PM
05/03/09 08:52 PM
Lightning
Augusta, GA
Sure, it could be adapted. But for the time, effort, and cost of making a Howe arm fit, it would be easier to just go to the local pick a part and get the correct arm for $10.
Oz, FJM upper arms are more like a chevy arm than traditional mopar arms. They have a cross shaft and use shims for alignment.
I'm still needing the adjustability though.
[Re: Lightning]
#306838
05/04/09 01:59 PM
05/04/09 01:59 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Might be better off with one of these that comes with the cross shaft installed. Without comparing the chevy against the mopar, you may use up all the adjustment to get the caster set up, plus the cross shaft bolt pattersn and width are most likely not going to match either. But, your dime and your time. http://www.speedwaymotors.com/Adjustable-A-Arms-With-Cross-Shafts,2117.html If you going to convert to coil overs later, don't forget you'll need to add a strut rod or some other triangulation device to the lower control arm as well.
[Re: TC@HP2]
#306839
05/04/09 02:21 PM
05/04/09 02:21 PM
Lightning
Augusta, GA
yeah, the strut rod is in the works too. ok, another question inside this question. The car's gonna be going drifting too, so I'm needing to radically increase the amount of steering angle I have. I'm gonna move the tie rod connection point on the knuckle closer to the pivoting axis, like this:----> and, granted it's on another car, another couple examples: can ya'll think of anything else I can do for more steering angle? Yes, I'm starting to think I'm nuts for attempting this.
[Re: Lightning]
#306840
05/04/09 02:46 PM
05/04/09 02:46 PM
autoxcuda
So Cal
like this:---->
Yes, buy a www.firmfeel.com quick ratio pitman arm. And C-body idler. Might put the center link in a slightly different location, but easier and stonger than then welded steering arm. Something to try, you are in the realm of heavy mods so no guarantees. Both longer pitman and shorter steering arm will change bump steer and akermann. Probably not a deal breaker with a drift car.
Steering angle is going to be limited by rim offset and tire to frame clearance I would think.
[Re: autoxcuda]
#306841
05/04/09 04:46 PM
05/04/09 04:46 PM
Lightning
Augusta, GA
like this:---->
oh, I forgot to say I've been talking to Firm Feel about the spindle mods, They think it should work.
I was thinking of running the 17x8 Cragar 8-hole rims, so it should have some more offset than the stock steelies
