Re: O2 sensor bung horizontal on TTI headers - BAD??
[Re: kielbasa]
#3068098
08/15/22 09:55 AM
08/15/22 09:55 AM
Posts: 2,937 A shed in England
Tig
A shed in England
It's not ideal but should be OK, I think best position is between 12 and 2 (or 10) O Clock. I have mine at 2 and 10, it's never been an issue. I think it's just to help with condensation which can shorten the life of the sensor.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Sammy]
#3068120
08/15/22 11:00 AM
08/15/22 11:00 AM
Posts: 8,186 Plymouth, MI
Blusmbl
Plymouth, MI
It's definitely preferred to have them with at least 10* of downward angle for the moisture concern, but I've also seen factory Harleys and some other bikes with the tip of the sensor pointing upward in the exhaust.
[Re: kielbasa]
#3068122
08/15/22 11:19 AM
08/15/22 11:19 AM
Tig
A shed in England
I just checked on our standard BMW 540 V8 and the O2 sensors for pre and post cat are at 9 oclock (one side only ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) ) . Had the car 10 years and never had a code come up for an O2 sensor. HTH's.
[Re: kielbasa]
#3068131
08/15/22 11:47 AM
08/15/22 11:47 AM
Posts: 275 Anchorage, Alaska
metallicareload
Anchorage, Alaska
Yes, I understand the reason and theory behind it (assuming TTI does also?) - just wondering how big of a deal is it. I'll call TTI and get their 2 cents. Hate to yank these headers and "fix" something from a company that claims they cater to "enthusiasts that demand the best"..... I wasn't happy about the angle either, but 10,000+ miles and no problems with the actual O2 sensors themselves ![drive drive](/ubbthreads/images/graemlins/custom/drive.gif)
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: kielbasa]
#3068158
08/15/22 01:10 PM
08/15/22 01:10 PM
Posts: 31,086 Oregon
AndyF
I called TTI... AndyF nailed it - they answered verbatim. Yes, everyone in the aftermarket world uses that same answer. "we've never had a problem", "you're the first to bring that up", "I'll talk to the engineer and see if he has any feedback for you", etc. SOP #1 in the blue folder by the door.
[Re: AndyF]
#3068165
08/15/22 01:22 PM
08/15/22 01:22 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Send it. My assumption for TTI's placement is clearance issues that could arise by putting it in any position other than horizontal. My guess is that is the easiest place to install one on a musclecar to avoid hitting something. Given all the variations of things done in prodcution and the way folls install engines in the cars. Just a guess, but it is not going to hurt anything you will find many production cars with similar locations. Moisture would be the only problematic issue.
[Re: BDW]
#3068166
08/15/22 01:23 PM
08/15/22 01:23 PM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
Under the car anything between 12-3 could potentially cause a clearance problem. I think 3 or 9 is the safest bet for a generic coverage.
Mine are at 3:00 and I have not had any sensor problems.
68 Barracuda Formula S 340
[Re: Tig]
#3068171
08/15/22 01:26 PM
08/15/22 01:26 PM
Posts: 19,654 north of coder
moparx
I just checked on our standard BMW 540 V8 and the O2 sensors for pre and post cat are at 9 oclock (one side only ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) ) . Had the car 10 years and never had a code come up for an O2 sensor. HTH's. my caravan has the post-cat sensor at almost 9 o'clock. it's got the factory pipe on it, so it works alright where it's at. the "bus" has almost 175k on it now, and never a problem. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: moparx]
#3068184
08/15/22 02:09 PM
08/15/22 02:09 PM
Posts: 762 Southington Ct.
turbobitt
Southington Ct.
Just run it, the orientation is just a guide for best practice and for the typical use that these cars will see will never have an issue. Mine are like that too but I had welded them in myself. There really isn't much room to put them in the ideal clocked location. AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: Bad340fish]
#3068377
08/16/22 07:40 AM
08/16/22 07:40 AM
Posts: 10,049 MN
JERICOGTX
MN
Mine are at 3:00 and I have not had any sensor problems. When I built my new headers, 3-9 were the only locations the sensor wouldn't hit the floor pan, or be hanging down.
69 GTX
68 Road Runner
