Axle bearings #3066366
08/08/22 08:59 PM
08/08/22 08:59 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
What are the thoughts on 83/4 rear axle bearings? OEM or the new sealed(Green) bearings? I have a rear outer seal leaking wheel bearing grease and at this moment up in the air to replace the one side or go to the sealed bearing set-up and do both.
Re: Axle bearings [Re: 340cpe] #3066390
08/08/22 10:08 PM
08/08/22 10:08 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Go Green, I'm sure you'll hear all the horror stories and arm chair engineering suppositions, but in my experience with most Green Bearing naysayer's is that any failures are usually a case of operator error/installation error, I've been running various generations/designs of Green Bearings in multiple vehicles for decades with ZERO failures, street/strip/road course......
Re: Axle bearings [Re: DAYCLONA] #3066438
08/09/22 06:51 AM
08/09/22 06:51 AM
Mass
charge70 Offline
charge70  Offline
Mass
Just remember,if you go green you have to remove the thrust block in the diff.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Axle bearings [Re: charge70] #3066440
08/09/22 07:11 AM
08/09/22 07:11 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Ive seen almost zero problems from oem bearings. I only have to replace them in rebuilding a rear end because of the said leaking grease seal. It’s usual the inner seal that lets 90 wt leak.
Re: Axle bearings [Re: fastmark] #3066688
08/09/22 10:04 PM
08/09/22 10:04 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
So true. "Green" bearings was just a marketing ploy to replace tapered with standard (cheaper) roller bearings. Using the claim of no-more-axle-play adjustment, as if that is a really hard task to do.
Similar to the POR-15 products: Take an existing industrial coating, market it as "Paint" Over Rust for the automotive field. That sure was a "winner".
Re: Axle bearings [Re: PhillyRag] #3066695
08/09/22 10:22 PM
08/09/22 10:22 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thank You I was leaning toward tapered and have now made up my mind.
Re: Axle bearings [Re: 340cpe] #3066739
08/10/22 08:09 AM
08/10/22 08:09 AM
GMP440 Offline
GMP440  Offline
I would stay with the OEM bearings. Mine been on for years. Outer rear axle seal; not a big deal to change. Just undo the flange nuts, pull the axle, pull out the old seal, put in the new seal.
Forgot to ask, is an early 8 3/4 rear with the tapered bearings?
Re: Axle bearings [Re: PhillyRag] #3066798
08/10/22 12:44 PM
08/10/22 12:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
This. Many people are intimidated by a simple procedure.
Re: Axle bearings [Re: 340cpe] #3066842
08/10/22 03:04 PM
08/10/22 03:04 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
leaking? if the end play is too loose it wear out the seals
0.0030-0.0050 inches end play
green bearings are over rated and not recommended for road course laps no matter what the talented dayclona says. up
i have way more many hot laps than he does...lol
Re: Axle bearings [Re: 340cpe] #3066912
08/10/22 08:26 PM
08/10/22 08:26 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
DrDiff article
Personally I feel the sideload argument is invalid because either bearing is stronger than the retainer plate. As DrDiff pointed out in the above link people that have had problems with Greens are probably using the early version that some suppliers still sell.
I guess if I was going to roadrace and the axle bearings were keeping me awake at night I would call Mark Williams and ask them instead of asking for opinions on a forum.
Re: Axle bearings [Re: GomangoCuda] #3066971
08/11/22 12:31 AM
08/11/22 12:31 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Originally Posted by GomangoCuda
DrDiff article
It's not the overall strength of the bearing, but rather the use of the bearing. Tapered, by design, are for axial loads & radial loads. Non-tapered for radial only. Axial loads are present when turning.
Either will probably be fine with a car seeing road few miles, but that's not the designers' had in mind then.
Re: Axle bearings [Re: charge70] #3067210
08/11/22 11:20 PM
08/11/22 11:20 PM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
You only have to remove the thrust buttons if your diff has those - if you have a thrust block, it is retained on the cross pin and can't go anywhere. You'll just want to make sure you aren't bottomed out on it.
There was such bad tolerance stack in my E-body 8-3/4 that with the factory axles/bearings, the adjuster had pulled the right side axle to the point the brake drum was lightly touching the backing plate when you'd go around corners. I switched to the green style bearings so I'd have controlled end stick out distance on each side.
Overall, neither bearing design is perfect. Tapered bearings work best in pairs (reference front wheel bearing design) and handle side loads better; the tapered type bearing wants to naturally walk out of the race due to the angle. The mopar adjuster design works with the tapered bearings because of the ability to adjust end play, other makes don't have that ability. The "green" style roller bearings don't handle side loads well but don't require the setup effort. If you aren't autocrossing or road course racing the car, you aren't going to generate enough side load to trash the green/roller bearings. If you look at Moser, Strange, and even Mark Williams, they sell sealed ball bearings with their axles as standard. If that style bearing was a liability, you wouldn't see everyone using them. Just two different approaches...
Re: Axle bearings [Re: 83hurstguy] #3067390
08/12/22 04:07 PM
08/12/22 04:07 PM
GomangoCuda Offline
GomangoCuda  Offline
∆∆∆∆. Exactly. The O.P. is not doing the type of racing that needs a tapered roller so either should work fine. However the adjustable tapered bearing as opposed to fixed location ball bearing could cause issues with disc brakes. That's could not will. Just throwing that out there.
Do racecars that heavily sideoad like Nascar, Indy or F1 use single tapered bearings like we are discusing or do they us opposed tapered bearings and floating axles? Just curious.
Re: Axle bearings [Re: GomangoCuda] #3067584
08/13/22 11:18 AM
08/13/22 11:18 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
F1 uses a ball bearing but not a single-row like the Green, they use dual preloaded ball bearings.
Re: Axle bearings [Re: John_Kunkel] #3067763
08/14/22 03:30 AM
08/14/22 03:30 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Are those bearings spherical or cylindrical?
Re: Axle bearings [Re: GomangoCuda] #3068021
08/14/22 10:28 PM
08/14/22 10:28 PM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
Last time I checked, Nascar was using 9" rears with super speedway floater ends - there were opposed pairs of tapered bearings in each hub.
Re: Axle bearings [Re: PhillyRag] #3068082
08/15/22 09:30 AM
08/15/22 09:30 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
They would have to be spherical.
Re: Axle bearings [Re: JohnRR] #3068343
08/15/22 11:24 PM
08/15/22 11:24 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
They would have to be cylindrical.
On 2nd look, you are correct. My Bad.
Re: Axle bearings [Re: PhillyRag] #3068396
08/16/22 09:05 AM
08/16/22 09:05 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
My bad I copy and pasted the wrong word , they are spherical , the drawing make then look like a cylinder because that is how a 2d drawing makes a BALL look .
Re: Axle bearings [Re: 340cpe] #3068733
08/17/22 06:26 AM
08/17/22 06:26 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Either. Likely stock type since I have a few new sets on the shelf.
The green bearing do move the axles inward slightly and if the carrier has the thrust block it often will pre-load the green bearings.
You can remove the thrust block, or grind a bit off the end of the axle(s), or add a shim between the brake backing plate and axle flange.
