Compression Calculation Needed #3067551
08/13/22 09:46 AM
08/13/22 09:46 AM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
Can anyone figure out what compression would calculate to with pistons I found for 426 hemi. Would be appreciated. Thanks
Bore 4.375
Stroke 4.15
Deck height 10.720
Piston comp height 1.665
Effective volume 82.1cc
Rod 6.860
Head stock 174 cc
Head gasket thickness ???
Re: Compression Calculation Needed [Re: maximus] #3067560
08/13/22 10:09 AM
08/13/22 10:09 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Diamond has a good online calculator.
You'll need piston dome cc.
Would also recommend measuring the combustion chambers if you want to be accurate as "stock" isn't always the same.
Re: Compression Calculation Needed [Re: INTMD8] #3067811
08/14/22 11:42 AM
08/14/22 11:42 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Agreed there are many on-line calcs but you'd need to know how much positive CC the net volume is on the piston to be somewhat accurate without mocking it all up and doing the measurements. You may be able to find that looking up the piston on-line but again it will only give you a general idea.
