Re: Small block 727 brackets
[Re: TJP]
#3066049
08/07/22 02:12 PM
08/07/22 02:12 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Because the SB isn't a skirted block like the BB, more of the bellhousing extends below the block with no support; that's why the factory added the struts.
[Re: FurryStump]
#3066054
08/07/22 02:26 PM
08/07/22 02:26 PM
Posts: 6,228 nowhere
Sniper
nowhere
Unless you have the 727, I would go 904, it would need a different driveshaft than the 727, but I would not put a 727 behind a small block. I just changed from a 727 to a 904 and all said and done will have picked up 2.5 to 3 tenths. Now, I increased my flash rpm by 300, in the same dia converter. Both were PTC 9.5” converters. I also changed to the low gear set inside the 904. I also went aluminum for the driveshaft. So it is not just your typical 727 to 904 swap, but no more 727’s for me. Just not necessary. As an added benefit a much lower risk of shattering the drum. This isn't the race forum and no asked about picking up a tenth.
[Re: Sniper]
#3066176
08/08/22 10:09 AM
08/08/22 10:09 AM
Posts: 2,814 Connecticut
FurryStump
Connecticut
Unless you have the 727, I would go 904, it would need a different driveshaft than the 727, but I would not put a 727 behind a small block. I just changed from a 727 to a 904 and all said and done will have picked up 2.5 to 3 tenths. Now, I increased my flash rpm by 300, in the same dia converter. Both were PTC 9.5” converters. I also changed to the low gear set inside the 904. I also went aluminum for the driveshaft. So it is not just your typical 727 to 904 swap, but no more 727’s for me. Just not necessary. As an added benefit a much lower risk of shattering the drum. This isn't the race forum and no asked about picking up a tenth. True, but he’s running headers so he probably isn’t a restoration/date code/part number guy. If he has nothing on hand there is no reason to run a 727, except if he cares that it might have come with one originally. Racing or not, do you want to run a less efficient transmission? More power to the wheels, better mileage, safer, comparable cost. Valuable info no matter what you are doing with the car.
[Re: FurryStump]
#3066326
08/08/22 07:31 PM
08/08/22 07:31 PM
Posts: 1,456 oklahoma
forphorty
oklahoma
Unless you have the 727, I would go 904, it would need a different driveshaft than the 727, but I would not put a 727 behind a small block. I just changed from a 727 to a 904 and all said and done will have picked up 2.5 to 3 tenths. Now, I increased my flash rpm by 300, in the same dia converter. Both were PTC 9.5” converters. I also changed to the low gear set inside the 904. I also went aluminum for the driveshaft. So it is not just your typical 727 to 904 swap, but no more 727’s for me. Just not necessary. As an added benefit a much lower risk of shattering the drum. This isn't the race forum and no asked about picking up a tenth. True, but he’s running headers so he probably isn’t a restoration/date code/part number guy. If he has nothing on hand there is no reason to run a 727, except if he cares that it might have come with one originally. Racing or not, do you want to run a less efficient transmission? More power to the wheels, better mileage, safer, comparable cost. Valuable info no matter what you are doing with the car. agree
[Re: forphorty]
#3066335
08/08/22 07:59 PM
08/08/22 07:59 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
Unless you are planning Dukes of Hazzard jumps, the small block will survive just fine without the extra support brackets. I ran a lot of SB Mopars with an auto on a dirt track, all without the extra brackets, and never had a single issue. I can almost promise you are not going to put your Dart through what those old dirt track cars went through.
As to the 904/727 deal. If both are box stock transmissions, the 727 will hold up much better under abuse then a 904 will. If the trans is being built, then the 904 can probably hang with a box stock 727, but if both are being built, the 727 is a very tough trans and can take a lot of abuse. I tend to kill auto transmissions. Its 727s for me. I've killed way more 904 then I ever killed 727s, and I've had more 727s.
Of course, your mileage may differ.
[Re: FurryStump]
#3066358
08/08/22 08:37 PM
08/08/22 08:37 PM
Posts: 5,613 Detroit area
6PAX
Detroit area
True, but he’s running headers so he probably isn’t a restoration/date code/part number guy. If he has nothing on hand there is no reason to run a 727, except if he cares that it might have come with one originally. Racing or not, do you want to run a less efficient transmission? More power to the wheels, better mileage, safer, comparable cost. Valuable info no matter what you are doing with the car. Not a numbers car nor stock in appearance/build but it is an original 340 car so I would assume had it originally been an automatic it would have had a 727. I do already have a stock 727 I planned on using and I do plan on putting a shift kit in it. I don't think I'll bother with the brackets
[Re: 6PAX]
#3066471
08/09/22 09:29 AM
08/09/22 09:29 AM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
True, but he’s running headers so he probably isn’t a restoration/date code/part number guy. If he has nothing on hand there is no reason to run a 727, except if he cares that it might have come with one originally. Racing or not, do you want to run a less efficient transmission? More power to the wheels, better mileage, safer, comparable cost. Valuable info no matter what you are doing with the car. Not a numbers car nor stock in appearance/build but it is an original 340 car so I would assume had it originally been an automatic it would have had a 727. I do already have a stock 727 I planned on using and I do plan on putting a shift kit in it. I don't think I'll bother with the brackets You will have to spend $$$ to make it live behind the 340, unless it's a show poodle you are just driving on and off a trailer .
[Re: JohnRR]
#3066502
08/09/22 11:31 AM
08/09/22 11:31 AM
FurryStump
Connecticut
I think, all 340’s came with 727’s originally, but could be wrong. My 68 340 did. You have the 727 then it is probably the way to go. Doesn’t take anything really exotic to make a 904 live at a pretty serious power level, but as stated above, your mileage may vary. Two more things you need to address with a 904 than with a 727. Pump drive and high gear clock spring, (if you are going to spin it a bit) Billet servo’s? probably good idea for both, quality steels clutches?, both. Billet lever? Really depends on the valve body/line pressure. Sprag? Rebuilt 904 is good for most street car apps. 727? You want the best one you can get. Billet drum? Not really needed in 904. Good quality bands for both. If you really search for the best price, not much more than a comparable 727. If you are going through the transmission, the cost difference to fix the most common issues isn’t much more than a totally stock rebuild for either transmission.
[Re: FurryStump]
#3066562
08/09/22 02:35 PM
08/09/22 02:35 PM
Sniper
nowhere
Unless you have the 727, I would go 904, it would need a different driveshaft than the 727, but I would not put a 727 behind a small block. I just changed from a 727 to a 904 and all said and done will have picked up 2.5 to 3 tenths. Now, I increased my flash rpm by 300, in the same dia converter. Both were PTC 9.5” converters. I also changed to the low gear set inside the 904. I also went aluminum for the driveshaft. So it is not just your typical 727 to 904 swap, but no more 727’s for me. Just not necessary. As an added benefit a much lower risk of shattering the drum. This isn't the race forum and no asked about picking up a tenth. True, but he’s running headers so he probably isn’t a restoration/date code/part number guy. If he has nothing on hand there is no reason to run a 727, except if he cares that it might have come with one originally. Racing or not, do you want to run a less efficient transmission? More power to the wheels, better mileage, safer, comparable cost. Valuable info no matter what you are doing with the car. So what? The 727 is more than sufficient to handle a 340. The same cannot be said about a stock 904. Safer? Not stock it ain't. Comparable cost? Not finished it isn't. maybe a core to build is comparable in cost but a stock 727 is all that is needed to handle the load, a 904 needs lots of costly parts to do the same. To be honest, if I was going to make the mistake of putting an automatic in place of a stick it wouldn't be either the 727 or 904 varieties. I'd get one with an OD gear.
