A/C #3065474
08/05/22 01:01 PM
08/05/22 01:01 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
Ok, I have a 88 truck with air, it has a somewhat new compressor that was on it when I got it. As far as I know, everything else is original I had it changed over to 135 and it will only get down to around 60 degrees, my question is should other parts have to be changed out to make it work on 135?
Re: A/C [Re: 71birdJ68] #3065482
08/05/22 01:40 PM
08/05/22 01:40 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
No other parts. What are the pressure readings.
Re: A/C [Re: NITROUSN] #3065501
08/05/22 02:59 PM
08/05/22 02:59 PM
Morristown Tn.
Morristown Tn.
Don't know, I had a shop do it. He does all of my cars, so I trust him.
Re: A/C [Re: 71birdJ68] #3065502
08/05/22 03:03 PM
08/05/22 03:03 PM
N
N
Without pressures stated help is just guessing.
Re: A/C [Re: NITROUSN] #3065736
08/06/22 11:49 AM
08/06/22 11:49 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
88 was still using R12. What compressor is it for. Also the oil for R12 is not compatible with R134. It may work but not a well as with the correct oil/refrigerant.
Re: A/C [Re: Moparite] #3065872
08/06/22 07:51 PM
08/06/22 07:51 PM
Morristown Tn.
Morristown Tn.
Yes, it should have R12 and they had already switched over to the rotary compressor in the early 80's. I don't know what brand the compressor is, just that it isn't original. I'm wondering if any of the other stuff like condenser has to be changed also.
Re: A/C [Re: 71birdJ68] #3065966
08/07/22 03:39 AM
08/07/22 03:39 AM
Guitar Jones Offline
When I convert these trucks I always replace the evaporator, condenser and drier. If the compressor is still good I remove it and drain all the oil, flush the lines then install the correct amount of PAG oil in the compressor. I also install two small 10" , 1000 CFM fans on the condenser. Getting good air flow across the condenser is key to making them cool and keeping the high pressure readings down with the amount of refrigerant I'm going to put in it. I vacuum it for a couple hours then charge it with 3 cans of r134a.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
