Putting k member back in with suspension on it
#3065601
08/05/22 08:19 PM
08/05/22 08:19 PM
Posts: 1,032 illinois
bigblk66_coronet
illinois
So i ve run into a little problem. We dropped the motor and trans and k member out of the bottom of my coronet. we did it on a lift. My guy is moving out of state next month so there is no lift to put it back in. We just ran out of time. So i need to get the k member back in the car and it still has suspension on it. Any ideas on the best way to go about this or is it gonna be a nightmare no matter what? Just not even sure where to start. anyone? Thanks Joe
66 Dodge Coronet 500
440w/727
11:10 30 over 440 w/292 purple shaft,stock Eddy heads,3:23,full exhaust
Best ET. 12.38 @110 in street trim
Re: Putting k member back in with suspension on it
[Re: Sniper]
#3065611
08/05/22 08:45 PM
08/05/22 08:45 PM
Posts: 43,590 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I have done it and have seen many others use an engine hoist to lift the car and drop it on the engine/trans/k-frame...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#3065616
08/05/22 09:02 PM
08/05/22 09:02 PM
bigblk66_coronet
illinois
the engine and trans wont be on the k member, thats was the original plan.
440w/727
[Re: bigblk66_coronet]
#3065627
08/05/22 09:24 PM
08/05/22 09:24 PM
Posts: 12,171 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
We have in the past removed the bumper and bolted some channel iron to the frame with the bumper bolts, then lift the front of the car with a cherry picker or hoist attached to them. We usually have the upper control arms mounted in the body, not on the 'K' assembly.
Master, again and still
[Re: Cab_Burge]
#3065629
08/05/22 09:28 PM
08/05/22 09:28 PM
bigblk66_coronet
illinois
ive pulled the motor and trans and put it all back in in one shot 5 times in the 30 years ive owned it. the reason we didnt come up through the top was i had a horrific back injury in march and was in no shape to be laying on cement or bending over the fenders. So we decided to drop everything out the bottom. Problem is my buddy is closing his shop and moving to arkansas the middle of next month so now i have no lift. Still waiting on parts to build the motor. So i just want to get k member back in then when motor and trans are done they will have to go down in from the top. We just ran out of time. Ive never done it this way before so im clueless about how to go about it.
440w/727
[Re: Kern Dog]
#3065693
08/06/22 07:43 AM
08/06/22 07:43 AM
Posts: 8,294 fredericksburg,va
cudaman1969
fredericksburg,va
Take everything off K-frame, use a floor jack to lift and bolt it back to car (I’m assuming you have the car on jack stands) the rest is as simple as bolting on the parts in reverse order they came off. If your back is that bad, hire someone to put it back. PS before you start take pics from different angles for reference going back together. If you’ve had the motor out 5 times this should be a piece of cake but it sounds like you’re asking how without bending over.. no way.
[Re: cudaman1969]
#3065708
08/06/22 09:46 AM
08/06/22 09:46 AM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Take everything off K-frame, use a floor jack to lift and bolt it back to car This would be no more time-consuming than making the gadget to hook up an engine stand to raise the car.
