Suspension program or app #3065045
08/03/22 11:16 PM
08/03/22 11:16 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
I am setting up my ladder bars I was looking for a program or app that shows the Instant Center and other variables when you input data and the shows the difference when change things up.
Anyone have any suggestions?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Suspension program or app [Re: Kam*Kuda] #3065047
08/03/22 11:50 PM
08/03/22 11:50 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I think it’s baseline suspension, you might not find a ladder bar application because the instant center is fixed . You can plug your measurements into a 4 link app , just put both front upper and lower as the same , it will give you your anti squat %
....BAD A$$ STREET CAR.....
Re: Suspension program or app [Re: Kam*Kuda] #3065054
08/04/22 01:23 AM
08/04/22 01:23 AM
My old pump gas duster had 4 holes for the front mount, it liked the lowest one up scope
The best way for you to learn what your car likes and you like is to try it in all locations scope wrench uptwocents
Re: Suspension program or app [Re: Kam*Kuda] #3065069
08/04/22 07:46 AM
08/04/22 07:46 AM
N
n20mstr Offline
n20mstr  Offline
N
instant Center on a ladder bar is fixed, you can raise or lower it , but thats it
Raising or lower the front mount will change the height of the IC and the antisquat (Amount of Rise)
Kevin Wilson has some good youtube video of this, search it on YouTube
Re: Suspension program or app [Re: Kam*Kuda] #3065081
08/04/22 08:42 AM
08/04/22 08:42 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
http://performancetrends.com/4link.htm performance trends make a good program, it will do 4-link and ladder bar suspensions, I have used it for many years. It will also allow you to put the suspension in movement and see what happens as well.
Re: Suspension program or app [Re: jwb123] #3065134
08/04/22 11:35 AM
08/04/22 11:35 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You can't pin point I/C unless you know the exact C.G point . Otherwise it's only a guess. You can get a pretty good idea if you video the car. If if separates you are above the C.G.. If it squats (very unlikely with ladder bars) it's below the C.G. The more power you run. The lower you mount the front of the bar. Weight distribution, ride height, wheelbase, power level, SLR, tire type, track prep style all play into it. Need more info.
Doug
Re: Suspension program or app [Re: dvw] #3065154
08/04/22 12:32 PM
08/04/22 12:32 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I don't much care about IC. I pay attention to angles, heights, spreads, I will plot IC just as a piece of information that I can use. It is a result, not a setting for me.
That said, it can give you an idea of where you are going if you want to compare different geometries and settings. But it's the geometry that determines what happens.
As far as something or someone telling you where to put the bars, all anyone can do is give you a general starting point. 48" out - 7" up with the bottom bar level to 1* down. There you go.
Where to go from there depends on your video and what you want the car to do differently. Don't forget to use the shocks while sorting it all out.
Ladder bars are easier. Lower is less violent, higher is more violent. Use a good shock to control the separation.
Re: Suspension program or app [Re: CMcAllister] #3065175
08/04/22 02:13 PM
08/04/22 02:13 PM
My old Duster 60 ft. times got better after me swapping out the single adjustable (extension only) coil over to double adjustable up scope
