Spring tension on rocker arms #3063989
07/30/22 11:49 PM
07/30/22 11:49 PM
Out of the State of Confusion
blue_stocker Offline OP
While having a recent conversation about engine components, an interesting question arose about true rockerarm strength and deflection. In this case it had to do with the old Isky iron and MP aluminum units. Since I personally have never placed any real serious load on them (over 350#) we were wondering how much 'actual load' (not theorectical/wishful or imaginary tension) but actual spring load over the nose and through the cam ramp cycle these rockers would 'safely/effectively' take in race-type environment? It is a curiosity...
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: Spring tension on rocker arms [Re: blue_stocker] #3064013
07/31/22 06:51 AM
07/31/22 06:51 AM
NH, USA
toddinNH Offline
Egghead
toddinNH  Offline
Egghead
NH, USA
That's a tough call as the thoughtful racer will use lightweight valves, retainers, and springs(within reason) to achieve better valve control throughout the working RPM range.
Of course there are limits - where deflection becomes unacceptable - but without some fairly sophisticated measuring tools these limits are difficult to discern. A few hours of spintron work should provide all kinds of useful data regarding deflection under various spring force scenarios.
Re: Spring tension on rocker arms [Re: toddinNH] #3064024
07/31/22 08:44 AM
07/31/22 08:44 AM
A727Tflite Offline
A727Tflite  Offline
Several of us used the original MaxWedge and Isky rockers on our SS cars back in the 70’s.
We used the Direct Connection Triple and Battleship springs without any rocker arm failures.
If I recall correctly open pressures were close to 500.
Trick Titanium retainers and hard DC locks.
We only spun the motors around 6700-6800.
