Page 2 of 5 1 2 3 4 5
Re: Header thread [Re: n20mstr] #3016181
02/16/22 11:00 PM
02/16/22 11:00 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by n20mstr
Dumb question...other than durability and $$$ is there any difference between stainless and mild steel ???
Oh and i have some A body big block headers for sale in the race parts section whistling
Rust. Mild steel will rust inside, even if coated. Some of the rust scale will end up back in the cylinder.
Heat conduction. SS doesn't conduct heat as well. More heat stays in the exhaust gas.
Re: Header thread [Re: CMcAllister] #3016223
02/17/22 08:08 AM
02/17/22 08:08 AM
NW Indiana
fbs63 Online content
fbs63  Online Content
NW Indiana
Plus you can use 18 gauge tube.
Re: Header thread [Re: fbs63] #3016286
02/17/22 01:14 PM
02/17/22 01:14 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
16 gauge set, 30", 2.125 d, with 3/8" full flange and a merge collector is heavy. No doubt.
Re: Header thread [Re: CMcAllister] #3016356
02/17/22 06:23 PM
02/17/22 06:23 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
3/8 Flanges with added center bolts, no gaskets. 1 7/8" 321 stainless tube. Made a poor choice of having them ceramic coated. Burned off after the first few launches. Very expensive even doing it all myself. Worth every cent. Never needed any repairs even with torturous zero degree launch strategies.
Re: Header thread [Re: TRENDZ] #3016375
02/17/22 08:00 PM
02/17/22 08:00 PM
looks like to me that you are tempting fate with those extruded aluminum Crane rocker arms and using springs between them instead of shims and spacers twocents work
Murphy would have burnt any rig I worked on with twin turbos and solid roller cams with those rockers arms on my builds to the ground whiney work
Re: Header thread [Re: Cab_Burge] #3016382
02/17/22 08:21 PM
02/17/22 08:21 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
broke more than one exhaust rocker… that pic was to show the exhaust flange with center studs between the ports.
Re: Header thread [Re: Cab_Burge] #3016391
02/17/22 08:51 PM
02/17/22 08:51 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I also elongated the shafts using those stock hold downs laugh2
Re: Header thread [Re: J_BODY] #3016401
02/17/22 09:11 PM
02/17/22 09:11 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Wish I could link picts but I’m fortunate to live 50 miles from REF Unlimited home of “headers while you wait”. I’ve had Greg do two sets of pipe. Drop off at 7am, pickup by 2-3….. dudes an artist.
Re: Header thread [Re: J_BODY] #3016439
02/18/22 06:36 AM
02/18/22 06:36 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
got you both covered…
Re: Header thread [Re: TRENDZ] #3016468
02/18/22 10:34 AM
02/18/22 10:34 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I see some weight savings on your intake manifold bolts.....LOL
Joe
Re: Header thread [Re: jlatessa] #3016501
02/18/22 11:54 AM
02/18/22 11:54 AM
Shelby Twp. Mi
HardcoreB Offline OP
Shelby Twp. Mi
I KNOW you guys are just lightly jabbing or even adding constructive criticism but, it can read harsh. I just don't want to discourage ANYONE from posting pics. We can all gain from it. Thanks for adding to the thread again!
Re: Header thread [Re: HardcoreB] #3016521
02/18/22 01:18 PM
02/18/22 01:18 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
While definitely not a Mopar thought I would share some more headers. Vettes old small, pump gas street car headers to it's current racey ones boogie This is a stock front end car, stock steering, control arms and frame rails.
Street car days
Current headers
Re: Header thread [Re: Al_Alguire] #3016537
02/18/22 02:14 PM
02/18/22 02:14 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Street car days
Current headers
Ovaled tube in the second pic is interesting. You ever talk to someone at one of the big race shops about the effects of doing that? Maintaining the area as opposed to just beating a dent in it seems a better solution. Just wonder if it hurts it. Sometimes you just have to make it fit.
Re: Header thread [Re: CMcAllister] #3016548
02/18/22 02:40 PM
02/18/22 02:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Many other changes to those heads between those two pics. The last revision before the new headers was to move the exhaust valve guide/valve over to make more room for the largest intake valve we could get in that small chamber. The entire exhaust port was then reshaped for a much smaller valve. All the work was done by Slawko of course. But good catch smile FWIW these headers were done by REF in Kingman, Greg and the guys have YEARS of experience with everything from bracket stuff to comp. We hold the shop record for the longest amount of time a car has spent in the shop getting headers made. It was there 4.5 days. As Jay pointed out most stuff is in at breakfast and done by lunch or shortly there after.
Re: Header thread [Re: Al_Alguire] #3056739
07/06/22 02:40 PM
07/06/22 02:40 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
interesting reading for sure. Im making some fender exits now and its funny that to make them equal length in a tight space it requires a few "loops" I have been instructed that loops and bends are restrictive. Make them short and fewer bends instead of equal length and a lot of bends...ill post up some pics later tonight for all to see my sawzall
weld
....BAD A$$ STREET CAR.....
Re: Header thread [Re: n20mstr] #3056777
07/06/22 03:37 PM
07/06/22 03:37 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
B0C8E02B-0B6B-419C-BA20-40DF46CB3A0E.jpegB48D8B43-700E-492B-8FF7-B5F74FDCA9AE.jpegC11094DC-A8A9-4B38-A7DA-A1BB75F1AD3B.jpeg2B32E7BF-BD43-4571-9607-C0077B257960.jpeg
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Header thread [Re: pittsburghracer] #3056820
07/06/22 05:31 PM
07/06/22 05:31 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Re: Header thread [Re: CMcAllister] #3056833
07/06/22 05:57 PM
07/06/22 05:57 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I used to have the magazine this article was in originally, but just came across it online. It may be from 2003, but I believe most of the info is still pertinent. LINK
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Header thread [Re: Brad_Haak] #3056874
07/06/22 08:10 PM
07/06/22 08:10 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Came with car and the inner fenders were already cut
112DD6E4-8AAF-463B-A75D-1B62491F18C3.jpegC5AAB486-C270-4E9E-9788-CEBEF6AE7226.jpeg295F21FB-03EF-426F-BACC-97696794EF6E.jpeg
Re: Header thread [Re: actionange] #3056949
07/06/22 11:49 PM
07/06/22 11:49 PM
N
n20mstr Offline
n20mstr  Offline
N
It’s a start , I’m no professional
B8CAEB03-A769-477A-A19A-308657B0BD10.jpeg52EB5792-FD08-44BA-9878-B9AC804C2723.jpegA53BBAAA-9CBB-45B0-B442-06841C76132F.jpeg39A8DEB4-F938-49EB-8EBC-A838236297CF.jpeg
