Re: Jesel Belt drive?
[Re: Dragula]
#3063524
07/29/22 10:32 AM
07/29/22 10:32 AM
Posts: 2,933 A shed in England
Tig
A shed in England
Nope, I can't see how it would. You will have plenty of room for a stock w/p if you run an engine plate but you may need extra clearance or spacers it if you want to run the front mounted, belt driven distributor.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: mopar_mark]
#3063559
07/29/22 11:20 AM
07/29/22 11:20 AM
Posts: 16,929 NC
440Jim
NC
You might need to space water pump away to give clearance My experience with a 1/4" thick front motor plate was the aluminum water pump housing was just about touching the Jesel center bolt head without gaskets (I use RTV and no WP gaskets). Some water pump housings may need a little (~0.030") grinding or cutting on the back for good clearance.
