How’s this combo sound for cruising #3062847
07/26/22 08:36 PM
07/26/22 08:36 PM
houston texas
gremlinsteve Offline OP
houston texas
The current combo is
383 727. 8.75 with a 355 gear and 26.8 inch tires
I’d like to run a gearvendor unit to lower my 65-70 mph cruise rpm by 400 or 500 whatever it is
I’m also running a 2500 stall converter now. The cam is a 230/236 comp grind that has issues wanting to push through the brakes
Hence the upgrade to the 2400-2500 stall converter
What’s everyone’s opinion. Will the combo work?
I’d like to be 2500 rpm as close to 70 as possible
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: How’s this combo sound for cruising [Re: gremlinsteve] #3062956
07/27/22 10:06 AM
07/27/22 10:06 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Master, again and still
Re: How’s this combo sound for cruising [Re: gremlinsteve] #3063009
07/27/22 12:40 PM
07/27/22 12:40 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Unless you are running a lockup style 727, you need to consider what your cruise rpm will be v/s the converter rpm. If cruise is lower than the converter it might be a problem. You would need to discuss it with your converter manufacturer.
Re: How’s this combo sound for cruising [Re: gremlinsteve] #3063019
07/27/22 02:03 PM
07/27/22 02:03 PM
Finding and buying a good torque converter can be very challenging, especially on the street: whiney:
I've raced Mopar BB and 426 hemi motors a lot of years and went through several different good converter companies shruggy work
The best street and strip converter I was able to buy and use was a Turbo Action 8 ich SS/AA race converter that I was able to buy from a SS/AA racer in SO CA years ago, I bought a T/A nine inch from him also up
That 8 inch was really good on the street, especially at light part throttle driving up boogie
I have had really good success using FTI trannies converters these last two years up scope twocents
Re: How’s this combo sound for cruising [Re: mgoblue9798] #3063034
07/27/22 03:03 PM
07/27/22 03:03 PM
houston texas
houston texas
true i have a cheap hughs 2400 converter i assume that it "should" be ok for me i like fti and pro torque myself
i
Re: How’s this combo sound for cruising [Re: Cab_Burge] #3063035
07/27/22 03:04 PM
07/27/22 03:04 PM
houston texas
houston texas
thanks for your insight again. i appreciate it tremendously
Re: How’s this combo sound for cruising [Re: Cab_Burge] #3063131
07/27/22 09:38 PM
07/27/22 09:38 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The understatement of the decade twocents beer
Re: How’s this combo sound for cruising [Re: mgoblue9798] #3063133
07/27/22 09:40 PM
07/27/22 09:40 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: How’s this combo sound for cruising [Re: DaveRS23] #3063134
07/27/22 09:41 PM
07/27/22 09:41 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by DaveRS23
YOU NEED THIS up
Re: How’s this combo sound for cruising [Re: TJP] #3063215
07/28/22 09:42 AM
07/28/22 09:42 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
It took me 3 tries to get happy with my converter. And I have to pull the engine and tranny to change the converter. What a chore.
Re: How’s this combo sound for cruising [Re: DaveRS23] #3063291
07/28/22 01:16 PM
07/28/22 01:16 PM
moparx Offline
moparx  Offline
GER.............. laugh2 laugh2 laugh2 panic
beer
Re: How’s this combo sound for cruising [Re: moparx] #3063344
07/28/22 03:38 PM
07/28/22 03:38 PM
houston texas
houston texas
beer
lol i remember that company
Re: How’s this combo sound for cruising [Re: moparx] #3063393
07/28/22 06:10 PM
07/28/22 06:10 PM
beer
puke puke puke shruggy
