Street 496 Dyno numbers are in... #3062667
07/26/22 11:17 AM
07/26/22 11:17 AM
Bowling Green KY / Nashville, ...
300by500 Offline OP
300by500  Offline OP
Over TEN YEARS ago I built a 440 with a 4.15 crank (496 CID), Ross 11:1 piston on Eagle H-beams with Chevy pins, Edelbrock 7193 intake, Hughes "prepped" Edelbrock heads, Hughes SEH4652BL hydraulic cam (see card, using 1.6 rockers).
Life happened and it sat there waiting..... a few weeks ago we FINALLY fired it up and put it on the dyno. I was hoping for 575 HP and 600 TQ, but I was doing the Snoopy Dance when the numbers came up!
Re: Street 496 Dyno numbers are in... [Re: 300by500] #3062691
07/26/22 11:50 AM
07/26/22 11:50 AM
an8sec70cuda Offline
Nice! That ought to be a real nice stump pulling street motor.
The pics don't work for me, but I assume it made more than you hoped for!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Street 496 Dyno numbers are in... [Re: an8sec70cuda] #3062695
07/26/22 11:54 AM
07/26/22 11:54 AM
300by500 Offline OP
300by500  Offline OP
It made 639 HP and 675 TQ, I was really surprised!
Re: Street 496 Dyno numbers are in... [Re: 300by500] #3062698
07/26/22 11:58 AM
07/26/22 11:58 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Re: Street 496 Dyno numbers are in... [Re: 300by500] #3062713
07/26/22 12:18 PM
07/26/22 12:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That's a great build there, the numbers seem impressive and way up there, and I have to admit I like that it's a hydraulic flat tappet.
what is it going into?
Rich H.
Esse Quam Videri
Re: Street 496 Dyno numbers are in... [Re: ZIPPY] #3062717
07/26/22 12:21 PM
07/26/22 12:21 PM
Kirkland, Washington
Pacnorthcuda Offline
Impressive is an understatement!
Re: Street 496 Dyno numbers are in... [Re: 300by500] #3062731
07/26/22 12:58 PM
07/26/22 12:58 PM
eek Wow, yeah that's way more than I would have thought from that combo! Nice!
CHIP
Re: Street 496 Dyno numbers are in... [Re: 300by500] #3062756
07/26/22 02:08 PM
07/26/22 02:08 PM
AndyF Offline
AndyF  Offline
That is a ton of torque for that size of engine. Should be a lot of fun on the street. You won't need steep gears out back, probably run as hard as you want with 3.54 or 3.70 gears.
Re: Street 496 Dyno numbers are in... [Re: AndyF] #3062763
07/26/22 02:24 PM
07/26/22 02:24 PM
White House,TN
stroked470 Offline
stroked470  Offline
White House,TN
I see Frank in the back ground doing some tuning. That is impressive for sure.
Re: Street 496 Dyno numbers are in... [Re: 300by500] #3062768
07/26/22 02:58 PM
07/26/22 02:58 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
very impressive #'s for the build.
Re: Street 496 Dyno numbers are in... [Re: ZIPPY] #3062783
07/26/22 04:15 PM
07/26/22 04:15 PM
300by500 Offline OP
300by500  Offline OP
69 Barracuda fastback, mini-tubbed, 727, 8-3/4 with a 3.91 gear.
Re: Street 496 Dyno numbers are in... [Re: stroked470] #3062786
07/26/22 04:17 PM
07/26/22 04:17 PM
300by500 Offline OP
300by500  Offline OP
Thanks! We really didn’t tune it too much, just bumped the timing from 36° total up to 37° We were running the shop’s 830 CFM carburetor. I’ve got a Sniper system for it, so hopefully there’s even a little more in it?
Re: Street 496 Dyno numbers are in... [Re: 300by500] #3062787
07/26/22 04:29 PM
07/26/22 04:29 PM
I've seen similar results with similar parts more than once up
Dan,AKA Dram, (may he R.I.P.) didn't believe those results years ago shruggy
My first pump gas stroker 400 with 4.250 stroke and 4.375 bore with 9.25 to 1 compression ratio with a set of ported big valve iron 906 heads with a low deck six pack Eddy intake set up with OEM 440 six pack carbs modified by C&J engr..made 612 HP at 5500 RPM and 644 Ft. lbs. at 4500 RPM using CA 91 octane pump swill boogie
Your heads are probably better than my old ones were up
Be VERY careful with your new found power, it can bite you luck
Re: Street 496 Dyno numbers are in... [Re: 300by500] #3062835
07/26/22 07:30 PM
07/26/22 07:30 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I'd be dancing, too, with numbers like that!
Very nice results.
I wish I could have gone for crazy numbers on mine but it wouldn't work with the car.
- Stu Harmon
Re: Street 496 Dyno numbers are in... [Re: 300by500] #3062852
07/26/22 08:54 PM
07/26/22 08:54 PM
NY
B1duster Online content
B1duster  Online Content
NY
Nice build, great numbers !
Which edelbrock heads ?
Are they fully ported/ cnc ?
Pump gas ?
Re: Street 496 Dyno numbers are in... [Re: B1duster] #3062883
07/26/22 11:38 PM
07/26/22 11:38 PM
300by500 Offline OP
300by500  Offline OP
Pump gas ?
Just Hughes “prepped” Edelbrocks from 2010, on 93 octane gas.
Re: Street 496 Dyno numbers are in... [Re: 300by500] #3062928
07/27/22 08:58 AM
07/27/22 08:58 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Those are great numbers, congrats. That is what my12.5:1 511 makes according to my time slip and the Moroso slide rule and it's a bunch of fun to drive.
Re: Street 496 Dyno numbers are in... [Re: 300by500] #3062942
07/27/22 09:38 AM
07/27/22 09:38 AM
Better start saving for a better rearend. Sell the 8.75 before it grenades. twocents
CHIP
Re: Street 496 Dyno numbers are in... [Re: 300by500] #3062968
07/27/22 10:40 AM
07/27/22 10:40 AM
WI
mopar873 Offline
mopar873  Offline
WI
That torque curve is awesome. Car will be a beast...
Re: Street 496 Dyno numbers are in... [Re: 300by500] #3063531
07/29/22 10:43 AM
07/29/22 10:43 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice work!
