Street 496 Dyno numbers are in...
#3062667
07/26/22 11:17 AM
07/26/22 11:17 AM
Posts: 2,886 Bowling Green KY / Nashville, ...
300by500
Over TEN YEARS ago I built a 440 with a 4.15 crank (496 CID), Ross 11:1 piston on Eagle H-beams with Chevy pins, Edelbrock 7193 intake, Hughes "prepped" Edelbrock heads, Hughes SEH4652BL hydraulic cam (see card, using 1.6 rockers). Life happened and it sat there waiting..... a few weeks ago we FINALLY fired it up and put it on the dyno. I was hoping for 575 HP and 600 TQ, but I was doing the Snoopy Dance when the numbers came up! ![[Linked Image]](https://i.imgur.com/iZd2NpP.jpg) ![[Linked Image]](https://i.imgur.com/y64wIDN.jpg) ![[Linked Image]](https://i.imgur.com/pt2p4f3.jpg)
Re: Street 496 Dyno numbers are in...
[Re: 300by500]
#3062691
07/26/22 11:50 AM
07/26/22 11:50 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Nice! That ought to be a real nice stump pulling street motor. The pics don't work for me, but I assume it made more than you hoped for!
[Re: 300by500]
#3062713
07/26/22 12:18 PM
07/26/22 12:18 PM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
That's a great build there, the numbers seem impressive and way up there, and I have to admit I like that it's a hydraulic flat tappet.
what is it going into?
Rich H.
Esse Quam Videri
[Re: 300by500]
#3062731
07/26/22 12:58 PM
07/26/22 12:58 PM
an8sec70cuda
It made 639 HP and 675 TQ, I was really surprised! ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif) Wow, yeah that's way more than I would have thought from that combo! Nice!
[Re: ZIPPY]
#3062783
07/26/22 04:15 PM
07/26/22 04:15 PM
300by500
what is it going into? 69 Barracuda fastback, mini-tubbed, 727, 8-3/4 with a 3.91 gear.
[Re: stroked470]
#3062786
07/26/22 04:17 PM
07/26/22 04:17 PM
300by500
I see Frank in the back ground doing some tuning. That is impressive for sure. Thanks! We really didn’t tune it too much, just bumped the timing from 36° total up to 37° We were running the shop’s 830 CFM carburetor. I’ve got a Sniper system for it, so hopefully there’s even a little more in it?
[Re: 300by500]
#3062787
07/26/22 04:29 PM
07/26/22 04:29 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
I've seen similar results with similar parts more than once ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Dan,AKA Dram, (may he R.I.P.) didn't believe those results years ago ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) My first pump gas stroker 400 with 4.250 stroke and 4.375 bore with 9.25 to 1 compression ratio with a set of ported big valve iron 906 heads with a low deck six pack Eddy intake set up with OEM 440 six pack carbs modified by C&J engr..made 612 HP at 5500 RPM and 644 Ft. lbs. at 4500 RPM using CA 91 octane pump swill ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) Your heads are probably better than my old ones were ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Be VERY careful with your new found power, it can bite you ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif)
[Re: 300by500]
#3062835
07/26/22 07:30 PM
07/26/22 07:30 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I'd be dancing, too, with numbers like that!
Very nice results.
I wish I could have gone for crazy numbers on mine but it wouldn't work with the car.
[Re: 300by500]
#3062942
07/27/22 09:38 AM
07/27/22 09:38 AM
an8sec70cuda
Better start saving for a better rearend. Sell the 8.75 before it grenades. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
