Alternator restoration question. #3062594
07/25/22 11:59 PM
07/25/22 11:59 PM
GMP440 Offline OP
GMP440  Offline OP
I have a question about the color of the stator part of the alternator. Should that part be brown color with a clear coat or dark gold with a clear coat? What would be correct? Here is a pic of an alternator with the dark gold on the stator part. Thanks.
Re: Alternator restoration question. [Re: GMP440] #3062602
07/26/22 01:38 AM
07/26/22 01:38 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I used to sell the thin steel sheet with certain magnetic properties that was stamped and stacked for stators and similar. Nobody paints that stuff with color paint. I believe after units are stacked, the stack is dipped in transparent lacquer or maybe it is shellac. So you are looking at the sheared edges coated with lacquer or shellac that has a natural light yellow-brown tint.
Restoration by Jim Ridge, Dixie Restorations. The front and rear aluminum castings should be coated with yellow Alodine.
2Johnston, Kent Post-restoration of Dixie core 001.JPG2Johnston, Kent Post-restoration of Dixie core 002.JPG
Re: Alternator restoration question. [Re: kentj340] #3062608
07/26/22 07:11 AM
07/26/22 07:11 AM
GMP440 Offline OP
GMP440  Offline OP
So, looks like we are in the ball park . Just need to coat with a tinge of brown and then shellac over that.
Re: Alternator restoration question. [Re: GMP440] #3062624
07/26/22 08:55 AM
07/26/22 08:55 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
What you are seeing is insulating varnish. Common on any stacked electrical core.
Re: Alternator restoration question. [Re: 6PakBee] #3062764
07/26/22 02:30 PM
07/26/22 02:30 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Over the years I have seen clear, red and green.
https://www.mcmaster.com/electrical-insulating-varnish/
Re: Alternator restoration question. [Re: John_Kunkel] #3062889
07/27/22 01:06 AM
07/27/22 01:06 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Yes, varnish. The stampings are stacked into units, wired, and lastly coated with insulating varnish. There is no coloration other than the clear insulating varnish in the case of Mopar alternators.
It's about the same look as you'd see on an old doorbell transformer.
