VP C-12
#3062499
07/25/22 03:38 PM
07/25/22 03:38 PM
Posts: 1,515 westerly, ri. usa
440lebaron
westerly, ri. usa
is to much octane to much? 400, stk 452 heads t/quad stock intake, headers, 4:56 gears 4100 lbs
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: VP C-12
[Re: 440lebaron]
#3062512
07/25/22 04:30 PM
07/25/22 04:30 PM
Posts: 988 Atlanta, GA
mgoblue9798
Atlanta, GA
You need to optimize dynamic compression, valve timing events, and ignition timing for a certain octane level -plus a little margin for safety. Any fuel with octane rating exceeding what the build is designed for is just wasted money.
Re: VP C-12
[Re: slantzilla]
#3062547
07/25/22 05:57 PM
07/25/22 05:57 PM
Posts: 14,171 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
In nhra stock, you have to run a fuel that’s on the approved list, and it will get checked after you make a pass most of the time.
Re: VP C-12
[Re: fast68plymouth]
#3062577
07/25/22 08:19 PM
07/25/22 08:19 PM
Posts: 40,819 Bend,OR USA
Cab_Burge
In nhra stock, you have to run a fuel that’s on the approved list, and it will get checked after you make a pass most of the time. how long ago did that start?
Re: VP C-12
[Re: FastmOp]
#3062609
07/26/22 06:18 AM
07/26/22 06:18 AM
440lebaron
westerly, ri. usa
no fuel check yet, 8-1 compression
Re: VP C-12
[Re: 440lebaron]
#3062628
07/26/22 08:26 AM
07/26/22 08:26 AM
Posts: 570 UK
rb446
UK
That'll run good on 87 prob, back in the day running my 440-6@9.8:1 with single 850DP I ran what we called 4 star leaded fuel, approx 97 octane, decided to add unleaded to it, and boy it sounded so much stronger, didn't go much faster but.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
Re: VP C-12
[Re: rb446]
#3062633
07/26/22 09:01 AM
07/26/22 09:01 AM
440lebaron
westerly, ri. usa
YEP, no pump gas in stock, running in super street SST to break in car, illegal 383 still waiting for piston for 400
Re: VP C-12
[Re: 440lebaron]
#3062639
07/26/22 09:10 AM
07/26/22 09:10 AM
fast68plymouth
So. Burlington, Vt.
“If it were me”, and I were running an 8:1 motor in Stock, I’d initially be using whatever was the least expensive legal fuel on the list.
After the car was sorted out and quite repeatable......... then you could experiment with some different fuels to see if there is a performance gain over the cheaper stuff.
Of course, I wouldn’t be messing around in S/St either. Just put the 383 in the car, with the correct cam, heads, intake, carb and start making runs. Swap the short block when the new 400 is ready.
Re: VP C-12
[Re: 83hurstguy]
#3062643
07/26/22 09:17 AM
07/26/22 09:17 AM
Posts: 539 Lake Villa Il
INTMD8
Lake Villa Il
Octane and the burn curve aren't necessarily related. High compression engines need higher octane and also typically operate at higher RPM ranges, which requires a faster burn...
You'll find that fuels have varying Reid vapor pressures that will help with intake charge cooling more than others, which may help increase power via better atomization/distribution. A lot of stock eliminator guys will typically run C11 or C12, and those engines have less than 10:1 compression and huge cams that produce low cranking compression. Some fuels like hot vs cool engines (or hot intake charges from boost).
That being said, many people use race fuel for consistency in tuning run to run (or class rules) even if the engine doesn't require it. I have a big block iron headed engine here with 10.5:1 compression that doesn't care whether it's on pump or C12 (it actually picked up a tick on pump on the dyno). My stock 440-6 has some preferences that show up on the dyno in terms of fuel, but it's maybe 5 hp difference.
Pump gas is inconsistent but also oxygenated, which can help make power. You may also find that race fuel has lower specific gravity than the pump gas you're running, which means you need to jet up to get the same power input.
Overall - fuel testing and tuning takes a lot of time and effort. It's definitely not as simple as the guy at the cruise night spouting off "yeah she really runs good with the race gas!" Good post, agreed.
69 Charger. 438ci Gen2 hemi. Flex fuel. Holley HP efi. 595rwhp 475rwtq.
Re: VP C-12
[Re: Cab_Burge]
#3062652
07/26/22 09:39 AM
07/26/22 09:39 AM
Posts: 176 PA
Scully
PA
In nhra stock, you have to run a fuel that’s on the approved list, and it will get checked after you make a pass most of the time. how long ago did that start? More than 30 years ago.
