VP C-12 #3062499
07/25/22 04:38 PM
07/25/22 04:38 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
is to much octane to much?
400, stk 452 heads t/quad stock intake, headers, 4:56 gears 4100 lbs
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: VP C-12 [Re: 440lebaron] #3062506
07/25/22 04:54 PM
07/25/22 04:54 PM
AndyF Offline
AndyF  Offline
Yes. Too much octane slows down the burn and makes the engine sluggish. It also burns a hole in your pocket.
Re: VP C-12 [Re: 440lebaron] #3062512
07/25/22 05:30 PM
07/25/22 05:30 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
You need to optimize dynamic compression, valve timing events, and ignition timing for a certain octane level -plus a little margin for safety. Any fuel with octane rating exceeding what the build is designed for is just wasted money.
Re: VP C-12 [Re: mgoblue9798] #3062525
07/25/22 06:07 PM
07/25/22 06:07 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Test
Test
Test ical
Re: VP C-12 [Re: 440lebaron] #3062529
07/25/22 06:13 PM
07/25/22 06:13 PM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
Octane and the burn curve aren't necessarily related. High compression engines need higher octane and also typically operate at higher RPM ranges, which requires a faster burn...
You'll find that fuels have varying Reid vapor pressures that will help with intake charge cooling more than others, which may help increase power via better atomization/distribution. A lot of stock eliminator guys will typically run C11 or C12, and those engines have less than 10:1 compression and huge cams that produce low cranking compression. Some fuels like hot vs cool engines (or hot intake charges from boost).
That being said, many people use race fuel for consistency in tuning run to run (or class rules) even if the engine doesn't require it. I have a big block iron headed engine here with 10.5:1 compression that doesn't care whether it's on pump or C12 (it actually picked up a tick on pump on the dyno). My stock 440-6 has some preferences that show up on the dyno in terms of fuel, but it's maybe 5 hp difference.
Pump gas is inconsistent but also oxygenated, which can help make power. You may also find that race fuel has lower specific gravity than the pump gas you're running, which means you need to jet up to get the same power input.
Overall - fuel testing and tuning takes a lot of time and effort. It's definitely not as simple as the guy at the cruise night spouting off "yeah she really runs good with the race gas!"
Re: VP C-12 [Re: FastmOp] #3062530
07/25/22 06:13 PM
07/25/22 06:13 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Is that the spec gas in Stock?
Re: VP C-12 [Re: slantzilla] #3062547
07/25/22 06:57 PM
07/25/22 06:57 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
In nhra stock, you have to run a fuel that’s on the approved list, and it will get checked after you make a pass most of the time.
Re: VP C-12 [Re: fast68plymouth] #3062577
07/25/22 09:19 PM
07/25/22 09:19 PM
how long ago did that start?
Re: VP C-12 [Re: Cab_Burge] #3062587
07/25/22 10:24 PM
07/25/22 10:24 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
8 years or so ago.
Re: VP C-12 [Re: slantzilla] #3062593
07/25/22 11:21 PM
07/25/22 11:21 PM
AZLIVN
SLO-KID Offline
SLO-KID  Offline
AZLIVN
13.5-1 439 small block 7800 shift point been on C-12 since dyno day.
Re: VP C-12 [Re: FastmOp] #3062609
07/26/22 07:18 AM
07/26/22 07:18 AM
westerly, ri. usa
westerly, ri. usa
no fuel check yet, 8-1 compression
Re: VP C-12 [Re: 440lebaron] #3062628
07/26/22 09:26 AM
07/26/22 09:26 AM
UK
rb446 Offline
rb446  Offline
UK
That'll run good on 87 prob, back in the day running my 440-6@9.8:1 with single 850DP I ran what we called 4 star leaded fuel, approx 97 octane, decided to add unleaded to it, and boy it sounded so much stronger, didn't go much faster but.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: VP C-12 [Re: rb446] #3062633
07/26/22 10:01 AM
07/26/22 10:01 AM
westerly, ri. usa
westerly, ri. usa
YEP, no pump gas in stock, running in super street SST to break in car, illegal 383 still waiting for piston for 400
Re: VP C-12 [Re: 440lebaron] #3062639
07/26/22 10:10 AM
07/26/22 10:10 AM
So. Burlington, Vt.
So. Burlington, Vt.
“If it were me”, and I were running an 8:1 motor in Stock, I’d initially be using whatever was the least expensive legal fuel on the list.
After the car was sorted out and quite repeatable......... then you could experiment with some different fuels to see if there is a performance gain over the cheaper stuff.
Of course, I wouldn’t be messing around in S/St either.
Just put the 383 in the car, with the correct cam, heads, intake, carb and start making runs.
Swap the short block when the new 400 is ready.
Re: VP C-12 [Re: 83hurstguy] #3062643
07/26/22 10:17 AM
07/26/22 10:17 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Good post, agreed. thumbs
Re: VP C-12 [Re: Cab_Burge] #3062652
07/26/22 10:39 AM
07/26/22 10:39 AM
PA
Scully Offline
Scully  Offline
PA
More than 30 years ago.
Re: VP C-12 [Re: Scully] #3062789
07/26/22 04:38 PM
07/26/22 04:38 PM
The last time my old M.W. race car ran in NHRA stock was in 1988, it ran better on VP C12 at that race than it had with the SO CA local race gas Daeco brand boogie
NHRA would check the polarity on gas in both SS and Stock but not in any of the Super heads-up classes back then shruggy
Both of those classes can be tough to do well in scope
good luck on your efforts up wrench grin
Re: VP C-12 [Re: AndyF] #3062809
07/26/22 05:52 PM
07/26/22 05:52 PM
Colo
P
PJ68RT Offline
PJ68RT  Offline
P
Colo
Engine masters octane testing
https://www.youtube.com/watch?v=ryqyTPfNj1Q
