Finally my turn for a what will it run? #306194
05/03/09 12:04 AM
05/03/09 12:04 AM
Out West
408strokerdart Offline OP
Out West
Well, I believe I will be making passes in the car as soon as the weather breaks and the stars align. Most have heard the combo, but here is the short list. Mono, Caltrac, Dana 60, 4.56 gear, 29.5 X 10.5 tire, 727 ProTrans with pro brake and Aluminum drums (std. gear ratios), 8" Ultimate Converter with 6200 stall, ShadyDell 417", Coleman W8's, 16.2:1, big roller, 2"-2 1/8" step headers, some fiberglass, guessing the car weighs about 3050 to 3100. The engine wasn't on the dyno so no numbers to pull from.
So, what do you think? First outing should be this coming week on either Wednesday or Friday.
Re: Finally my turn for a what will it run? [Re: 408strokerdart] #306195
05/03/09 12:37 AM
05/03/09 12:37 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
9.23 @ 146
Good luck, Brian. I hope I guessed too slow.
Re: Finally my turn for a what will it run? [Re: S/ST 3040] #306196
05/03/09 04:11 AM
05/03/09 04:11 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Brian, My guess is fast! No idea on et though. 16.2 to 1................ Are you running diesel fuel? LOL
Good luck buddy. I hope everything goes better than planned. And I know you have a plan. Later, John
Re: Finally my turn for a what will it run? [Re: Bigbeep] #306197
05/03/09 04:16 AM
05/03/09 04:16 AM
Arizona
Chris'sBarracuda Offline
Arizona
Definitely in the 8's..
Chris..
Re: Finally my turn for a what will it run? [Re: Chris'sBarracuda] #306198
05/03/09 05:50 AM
05/03/09 05:50 AM
Q
Quicktree Offline
Quicktree  Offline
Q
congrats it's going to be really fast.
Re: Finally my turn for a what will it run? [Re: Quicktree] #306199
05/03/09 09:37 AM
05/03/09 09:37 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Brian, where are you going to race? I say 8.90. I may want to see that bad boy come alive. Good luck!
Darren
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Finally my turn for a what will it run? [Re: ChrgrCuda] #306200
05/03/09 10:34 AM
05/03/09 10:34 AM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
I have alittle experience with this combo..sounds like it may need more gear and converter..but I would guess first time out it will be in the 9.40 range...hope I am wrong,but good luck
I think with some tuning should be ale to get it in the high teens..
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: Finally my turn for a what will it run? [Re: 408strokerdart] #306201
05/03/09 10:46 AM
05/03/09 10:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
9.20 @ 147
Re: Finally my turn for a what will it run? [Re: MR_P_BODY] #306202
05/03/09 11:05 AM
05/03/09 11:05 AM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Just keep it in one piece and hope that mid 9's and under and off the bumper are in the cards.
Re: Finally my turn for a what will it run? [Re: wheelsup68dart] #306203
05/03/09 11:57 AM
05/03/09 11:57 AM
Roanoke Va
gearjammerdart Offline
Roanoke Va
Hope it runs to your expectations Good luck and be careful.
Donald
69 Dart swinger 417 W8 Liberty 5 speed
6.03 @114/9.49 @141 on motor 5.30 @131 on juice 1/8th mile 28x10.5's at 3200lbs
70 Challenger RT 440 4-speed 4:10 Dana
http://www.youtube.com/watch?v=VowFy4nDdfI
Re: Finally my turn for a what will it run? [Re: gearjammerdart] #306204
05/03/09 12:35 PM
05/03/09 12:35 PM
Out West
Out West
I have my own guesses on what it will run. I will probably go 1/8 mile racing to Kennedale since they test and tune on Wednesdays. I would be happy with 6.0's the first time out with expectations that it can be tuned into the low 5.80 range. I guess this would equate to about 9.20? I really want an 8 second slip, but it is probably not in the cards with this package as is....maybe low 9 teens in mineshaft conditions.
Keep the guesses coming....
Re: Finally my turn for a what will it run? [Re: Bigbeep] #306205
05/03/09 12:37 PM
05/03/09 12:37 PM
Out West
Out West
Hi John. I am trying out VP Q16 at only $12/gallon . I have a plan.....to take it one step at a time.
Re: Finally my turn for a what will it run? [Re: ChrgrCuda] #306206
05/03/09 12:40 PM
05/03/09 12:40 PM
Out West
Out West
Darren
Darren,
Looks like it will be Kennedale, but will have to play it by ear on the weather. You are welcome to ride out there with us if you want. Just give me a call....I left my number in a PM.
Re: Finally my turn for a what will it run? [Re: 408strokerdart] #306207
05/03/09 12:46 PM
05/03/09 12:46 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
6.0's in the 1/8th is going to happen..the Q-16 is some power making stuff so make sure you have your tune-up on for it...
Re: Finally my turn for a what will it run? [Re: FASTFISH420] #306208
05/03/09 12:48 PM
05/03/09 12:48 PM
Out West
Out West
The engine was run in on the stand on Sunoco, so I upped the carb two sizes all around to hopefully sneak up on the tune up from the fat side.
Re: Finally my turn for a what will it run? [Re: 408strokerdart] #306209
05/03/09 12:56 PM
05/03/09 12:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I would think 9.20's will be doable when oy get it sorted out. On the Q, you may want to go a bit farther than 2 seizes for sure. It will like more fuel I would start at 4 basline. Just my
Re: Finally my turn for a what will it run? [Re: Al_Alguire] #306210
05/03/09 01:07 PM
05/03/09 01:07 PM
Out West
Out West
Thanks Al. I might just go up two more just to be safe. I have exactly 0 experience with this fuel.
Re: Finally my turn for a what will it run? [Re: 408strokerdart] #306211
05/03/09 11:40 PM
05/03/09 11:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
No problem...Oh one other thing...It smells, like Horsepower, but some say it stinks
Re: Finally my turn for a what will it run? [Re: Al_Alguire] #306212
05/04/09 10:08 AM
05/04/09 10:08 AM
Out West
Out West
Yeah Al, I was going to say it stinks....but as long as it makes HP who cares?
Re: Finally my turn for a what will it run? [Re: 408strokerdart] #306213
05/04/09 10:31 AM
05/04/09 10:31 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I am going to try to be out at Kennedale this coming Wednesday testing my small block some more as well. Hope the weather helps us out some. If it does I'll be there so if you need any help don't hesitate to ask. I'll be finding my tune up as well. I'll say 6.08@113 right off the trailer, and 5.92 by the end of the night.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
