Finally my turn for a what will it run?
#306194
05/03/09 12:04 AM
05/03/09 12:04 AM
Posts: 3,456 Out West
408strokerdart
Out West
Well, I believe I will be making passes in the car as soon as the weather breaks and the stars align. Most have heard the combo, but here is the short list. Mono, Caltrac, Dana 60, 4.56 gear, 29.5 X 10.5 tire, 727 ProTrans with pro brake and Aluminum drums (std. gear ratios), 8" Ultimate Converter with 6200 stall, ShadyDell 417", Coleman W8's, 16.2:1, big roller, 2"-2 1/8" step headers, some fiberglass, guessing the car weighs about 3050 to 3100. The engine wasn't on the dyno so no numbers to pull from. So, what do you think? First outing should be this coming week on either Wednesday or Friday.
Re: Finally my turn for a what will it run?
[Re: Quicktree]
#306199
05/03/09 09:37 AM
05/03/09 09:37 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Brian, where are you going to race? I say 8.90. I may want to see that bad boy come alive. Good luck!
Darren
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: ChrgrCuda]
#306200
05/03/09 10:34 AM
05/03/09 10:34 AM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
I have alittle experience with this combo..sounds like it may need more gear and converter..but I would guess first time out it will be in the 9.40 range...hope I am wrong,but good luck I think with some tuning should be ale to get it in the high teens..
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: Bigbeep]
#306205
05/03/09 12:37 PM
05/03/09 12:37 PM
408strokerdart
Out West
Brian, My guess is fast! No idea on et though. 16.2 to 1................ Are you running diesel fuel? LOL Good luck buddy. I hope everything goes better than planned. And I know you have a plan. Later, John
Hi John. I am trying out VP Q16 at only $12/gallon . I have a plan.....to take it one step at a time.
[Re: ChrgrCuda]
#306206
05/03/09 12:40 PM
05/03/09 12:40 PM
408strokerdart
Out West
Darren
Darren,
Looks like it will be Kennedale, but will have to play it by ear on the weather. You are welcome to ride out there with us if you want. Just give me a call....I left my number in a PM.
[Re: 408strokerdart]
#306207
05/03/09 12:46 PM
05/03/09 12:46 PM
FASTFISH420
Central,Ohio
6.0's in the 1/8th is going to happen..the Q-16 is some power making stuff so make sure you have your tune-up on for it...
www.URE-RACING.com
[Re: FASTFISH420]
#306208
05/03/09 12:48 PM
05/03/09 12:48 PM
408strokerdart
Out West
The engine was run in on the stand on Sunoco, so I upped the carb two sizes all around to hopefully sneak up on the tune up from the fat side.
[Re: Al_Alguire]
#306210
05/03/09 01:07 PM
05/03/09 01:07 PM
408strokerdart
Out West
I would think 9.20's will be doable when oy get it sorted out. On the Q, you may want to go a bit farther than 2 seizes for sure. It will like more fuel I would start at 4 basline. Just my
Thanks Al. I might just go up two more just to be safe. I have exactly 0 experience with this fuel.
#306213
05/04/09 10:31 AM
05/04/09 10:31 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I am going to try to be out at Kennedale this coming Wednesday testing my small block some more as well. Hope the weather helps us out some. If it does I'll be there so if you need any help don't hesitate to ask. I'll be finding my tune up as well. I'll say 6.08@113 right off the trailer, and 5.92 by the end of the night.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
