Valve covers on Trick Flow heads #3061802
07/23/22 10:04 AM
07/23/22 10:04 AM
Fairview Tennessee
SV_MOPARS Offline OP
Fairview Tennessee
any insight on what valve covers that fit the trick flow big block heads best sure would be helpful, i had planned on running the 440 source made in america fabbed covers but they have gone away because of covid for some unknown reason, does not matter if they are cast or fabbed, just want some that fit, i would be good with the trick flow covers ifn only they didnt have the "trick flow" script on them, i thought about getting a set of those and milling that off as a last resort.
Re: Valve covers on Trick Flow heads [Re: SV_MOPARS] #3061806
07/23/22 10:28 AM
07/23/22 10:28 AM
AndyF Online content
AndyF  Online Content
It isn't easy to find a set of big block valve covers that actually fit and seal up tight. The Indy and Trick Flow covers work great for race cars, but they don't have any holes in them so that can be a hassle for a street engine. I'm not aware of any good street valve cover that has an oil cap as well as a breather and PCV. I looked for a long time and I tried a bunch of different covers but they were all junk. I ended up making my own. The ones I made fit correctly and seal up tight.
Re: Valve covers on Trick Flow heads [Re: AndyF] #3061830
07/23/22 12:24 PM
07/23/22 12:24 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Re: Valve covers on Trick Flow heads [Re: SV_MOPARS] #3061878
07/23/22 03:47 PM
07/23/22 03:47 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I use the Mopar Performance Black Cast ones on my Trick Flow 240 heads using the Moroso rubber with steel valve cover gasket. Haven't had any issue or leaks in the 4 years I've had them on. I usually check the rocker arms once a season and reuse the same gaskets.
Re: Valve covers on Trick Flow heads [Re: DusterKid] #3061887
07/23/22 04:28 PM
07/23/22 04:28 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
The trick flow valve covers fit fine, they are raw and it's up to you to fit your own pcv, filler and baffle platea. Summit has a lot of different grommet mount and weld in stuff for the ports. I just cut the baffles put of 1/16 aluminum and welded them in, cleared the comp roller rockers just fine, even with the b3 shims.
Re: Valve covers on Trick Flow heads [Re: DusterKid] #3061888
07/23/22 04:30 PM
07/23/22 04:30 PM
okla.
sam64 Offline
sam64  Offline
okla.
The gasket surface on my trick flows were poorly machined.
Re: Valve covers on Trick Flow heads [Re: sam64] #3061921
07/23/22 07:13 PM
07/23/22 07:13 PM
Fairview Tennessee
Fairview Tennessee
thanks for the replies, i think i will try the summit ones, already on my wish list.
Re: Valve covers on Trick Flow heads [Re: AndyF] #3061923
07/23/22 07:15 PM
07/23/22 07:15 PM
Fairview Tennessee
Fairview Tennessee
andy i wish i would have bought that set from you when they were for sale.
Re: Valve covers on Trick Flow heads [Re: DusterKid] #3061924
07/23/22 07:17 PM
07/23/22 07:17 PM
Fairview Tennessee
Fairview Tennessee
i dont think those are being made anymore.
Re: Valve covers on Trick Flow heads [Re: SV_MOPARS] #3061926
07/23/22 07:18 PM
07/23/22 07:18 PM
birdtracker Offline
birdtracker  Offline
I have the Summit ones on my Trick Flow heads. They have an excellent gasket surface to seal. Birdtracker
Re: Valve covers on Trick Flow heads [Re: SV_MOPARS] #3061928
07/23/22 07:39 PM
07/23/22 07:39 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
I'm using the Summit valve covers also. I bought them maybe 6 years ago? The upper bolt holes were in the wrong location, too low, they might have fixed this since. Easy enough to fix with a die grinder. Also I had to put a small notch in the passenger side valve cover to clear the MSD distributor. I've probably had the valve covers off and on maybe a half dozen times this year alone, all in all the look good and seal well with Moroso 93055
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Valve covers on Trick Flow heads [Re: metallicareload] #3061953
07/23/22 10:27 PM
07/23/22 10:27 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
Its crazy how the location is different from each head manufacturer. That is why the valve cover holes are so big and even that doesn't always work.
In a previous post I posted the bolt hole dimensions of several heads including TF270. I have fixed several valve covers for folks over time to fit their heads..
Re: Valve covers on Trick Flow heads [Re: SV_MOPARS] #3061987
07/24/22 12:54 AM
07/24/22 12:54 AM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
Try searching e-bay for 440 fabricated valve covers. There's a bunch of them on there. beer
Re: Valve covers on Trick Flow heads [Re: super451b] #3062033
07/24/22 10:26 AM
07/24/22 10:26 AM
birdtracker Offline
birdtracker  Offline
The sealing surface on the fabricated is horrendous. I even tried taking a set to a belt sander. Birdtracker
Re: Valve covers on Trick Flow heads [Re: super451b] #3062036
07/24/22 10:42 AM
07/24/22 10:42 AM
There are a bunch of them. Most of them are junk. It is possible that someone somewhere makes some that work but I've never seen them. I've tried a bunch of different ones over the years and they have all been junk. Warped rails, holes drilled wrong, not enough clearance for the distributor, PCV and breather holes missing or wrong size, no baffles, etc.
Re: Valve covers on Trick Flow heads [Re: AndyF] #3062044
07/24/22 11:11 AM
07/24/22 11:11 AM
Washington
hemienvy Offline
hemienvy  Offline
Washington
Any positive comments on any of the old "Classic" cast covers,
like M/T, Cal Custom, Offy, Edelbrock ?
Re: Valve covers on Trick Flow heads [Re: hemienvy] #3062129
07/24/22 03:14 PM
07/24/22 03:14 PM
I haven't tried any of the older classic cast covers other than the Mopar Performance cover. The MP cast covers are too wide to seal properly. They are so wide that they shear a lot of gaskets and develop huge oil leaks. I found this out the hard way and was super sad when I figured it out since I had already invested in multiple sets of Mopar cast covers. I did eventually figure out that if you used the correct super thick fiber gasket from FelPro that you could kind of make the Mopar cast covers work. I would assume that the same is true for all of the old classic cast covers but I don't really know. I'd have to look at them and take some measurements before I knew if they would work.
After messing around with valve covers for a long time I finally figure out how to quickly tell if they will work or not. I built a little gauge tool that would show me if the valve cover would fit. Most valve covers fail the test. I'm not sure why, it isn't a difficult job to design a valve cover that works. I did it myself using a $99 CAD tool. So if I can do it so can any engineer working at any of the big places like Holley or Edelbrock.
Re: Valve covers on Trick Flow heads [Re: AndyF] #3062152
07/24/22 04:48 PM
07/24/22 04:48 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
I must have just gotten lucky. There wasn't a thing wrong with the ones that I got. My friend also bought a set for his small block and they were fine , as well.
