Re: Common to smell fuel vapors during warmer months?
[Re: vinnyd76]
#3061767
07/23/22 07:37 AM
07/23/22 07:37 AM
Posts: 6,225 nowhere
Sniper
nowhere
Saying "A body" is functionally useless.
My 72 Dart, an A body, had a charcoal canister to absorb fuel vapors. My 65 Cuda, another A body, does not, it has an open vent. I would not expect the 72 to smell, I would not be surprised if the 65 did.
So depending on what A body it actually is and whether or not any emissions devices, if there are any, are hooked up no one can answer your question.
[Re: Sniper]
#3061774
07/23/22 08:01 AM
07/23/22 08:01 AM
Posts: 1,562 Macomb, MI
vinnyd76
Macomb, MI
A-Body: 70 Dart One other note is his garage door does not open much…. works a lot.
[Re: topside]
#3061880
07/23/22 03:55 PM
07/23/22 03:55 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
Running stock/steel or aftermarket fuel hose?
I've found rubber a/n fuel hose can smell strongly of fuel vapor. I use only teflon now.
[Re: captaindodge]
#3062071
07/24/22 12:15 PM
07/24/22 12:15 PM
Posts: 1,696 central il.
second 70
central il.
What or where is the "fuel sender" ? It's the float assembly in the gas tank that sends info to fuel gauge. They have terminals where the wires hookup that can leak.
[Re: second 70]
#3062072
07/24/22 12:30 PM
07/24/22 12:30 PM
Posts: 20,169 Park Forest, IL
slantzilla
Park Forest, IL
"Racing fuel" depending on blend it could be eating a rubber hose or gasket.
How is the tank vented?
My car with an.open vent hose on the cell always smells like gas.
[Re: Cab_Burge]
#3062286
07/25/22 06:06 AM
07/25/22 06:06 AM
vinnyd76
Macomb, MI
. The empty VP jugs were checked and sealed.
[Re: captaindodge]
#3062287
07/25/22 06:17 AM
07/25/22 06:17 AM
vinnyd76
Macomb, MI
What or where is the "fuel sender" ? The fuel tank setup is stock. Reproduction steel fuel lines, then there is a small section of rubber hose between the sending unit to the steel fuel lines. I'm not sure on the sending unit if reproduction or rebuilt OE. I will need to follow-up on the sending unit, but the unit is installed in the fuel tank original setup.
[Re: vinnyd76]
#3062349
07/25/22 10:43 AM
07/25/22 10:43 AM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
The fuel tank and carburetor bowls are vented to the atmosphere.
Between the two, there is some evaporation at all times. In a fairly well sealed, not particularly well ventilated structure it will usually be noticeable.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3062425
07/25/22 01:53 PM
07/25/22 01:53 PM
vinnyd76
Macomb, MI
There is an indoor fan that turns on in the garage for a period of time during the day, but his main garage door does not open that often. They have a standard pedestrian door attached to the garage that the family uses to enter/exit. I told him to open the garage for a period of time to see if the smell goes away. The 70 Dart was filled (1/2 - 3/4 full) with fuel outside of the garage and then pulled back into the garage where it has sat for at least two weeks. I'm going to reach out later today to see if he went underneath the car over the weekend to see if there were any signs of fuel leaking.
[Re: vinnyd76]
#3062469
07/25/22 03:04 PM
07/25/22 03:04 PM
ZIPPY
S.E. Michigan
There is an indoor fan that turns on in the garage for a period of time during the day, but his main garage door does not open that often. They have a standard pedestrian door attached to the garage that the family uses to enter/exit. I told him to open the garage for a period of time to see if the smell goes away. The 70 Dart was filled (1/2 - 3/4 full) with fuel outside of the garage and then pulled back into the garage where it has sat for at least two weeks. I'm going to reach out later today to see if he went underneath the car over the weekend to see if there were any signs of fuel leaking. I went to great lengths to seal/insulate mine, and so far this has been the only drawback. After opening it up and doing an air exchange for a few minutes, it's fine for quite awhile. If the smell comes back immediately after being aired out, there is probably a leak somewhere but as said, definitely something to watch closely.
