Page 3 of 3 1 2 3
Re: 12 volt coil on an electronic ignition with ballast resistor [Re: SportF] #3061847
07/23/22 01:06 PM
07/23/22 01:06 PM
VA
dragon slayer Offline
VA
Originally Posted by SportF
Yes, the case is the ground. But the wire going into the cap has No connection to the case, or ground.
Sure it does via the dielectric which is a high resistance. So yes if you measured it with an ohm meter you see an open or a very high resistance in the Meg ohm range. A capacitor as it charges passes current. But it won't work unless the case is grounded. When it rises to the input voltage and is fully charged it than block any additional current flow.
There is no connection between the spark plug electrode and the frame, just air. But at a high enough voltage the air conducts. But if you don't ground the spark plug it can't spark.
Re: 12 volt coil on an electronic ignition with ballast resistor [Re: dragon slayer] #3061857
07/23/22 01:56 PM
07/23/22 01:56 PM
Minn
SportF Offline
SportF  Offline
Minn
If that was true the cap would discharge itself. I'm done.
Re: 12 volt coil on an electronic ignition with ballast resistor [Re: SportF] #3061869
07/23/22 03:02 PM
07/23/22 03:02 PM
VA
VA
Re: 12 volt coil on an electronic ignition with ballast resistor [Re: Sinitro] #3061889
07/23/22 04:35 PM
07/23/22 04:35 PM
mt pleasant pa
dodgedart340 Offline
mt pleasant pa
what is best timing for 1970 340 total and at idle and all in by what rpm
Re: 12 volt coil on an electronic ignition with ballast resistor [Re: dodgedart340] #3061891
07/23/22 04:53 PM
07/23/22 04:53 PM
Is this a serious question? If so, what application street, street and strip or drag race or circle track race?
Do you know if your balancer reads correctly in relationship to the zero timing mark on your balancer and on timing tab? If not verify that first and answer the other questions so we can give you the best advice for your deal
Re: 12 volt coil on an electronic ignition with ballast resistor [Re: Cab_Burge] #3061899
07/23/22 05:03 PM
07/23/22 05:03 PM
mt pleasant pa
mt pleasant pa
street use bal is true tdc on piston and bal right comp is 10.2 1 thanks
Re: 12 volt coil on an electronic ignition with ballast resistor [Re: dodgedart340] #3061909
07/23/22 05:59 PM
07/23/22 05:59 PM
Minn
SportF Offline
SportF  Offline
Minn
"When it rises to the input voltage and is fully charged it than block any additional current flow."
What about the 70% rule?
Re: 12 volt coil on an electronic ignition with ballast resistor [Re: dodgedart340] #3061962
07/23/22 10:59 PM
07/23/22 10:59 PM
I would recurve the distributor so it has between 32 to 34 max advance after 2400 RPM and set it up so it has between 12 and 18 degrees before top dead center at idle, under 1400 RPM.
Is this a iron head motor or aluminum head motor?
If iron heads be very careful on the spark plug heat range if it has a true compression ratio 10.2 to 1.
I would run the stock Champion plugs for it which I think was RN9YC, not any hotter tsk
On the Autolite brand I would try their 3923 or maybe the next colder 3922 if the 3923 run to hot scope
Re: 12 volt coil on an electronic ignition with ballast resistor [Re: Cab_Burge] #3062059
07/24/22 11:53 AM
07/24/22 11:53 AM
mt pleasant pa
mt pleasant pa
thanks now i know what way to head thanks again
Page 3 of 3 1 2 3
