Strut rod bushing #3061641
07/22/22 02:47 PM
07/22/22 02:47 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
How to remove strut rod bushing ? 1970 Plymouth B body
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Strut rod bushing [Re: GTXKARL] #3061670
07/22/22 04:52 PM
07/22/22 04:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A lot of how to information is on the web if you look for it. Should be the same for B bodies. https://www.forabodiesonly.com/mopar/threads/strut-rod-bushing-replacement.293562/
Re: Strut rod bushing [Re: GTXKARL] #3061733
07/22/22 10:10 PM
07/22/22 10:10 PM
remove the torsion bar on that side, disconnect the spindle form the lower control arm and slide the lower control arm back and remove and replace the bushing, reverse the procedure to reassemble it wrench scope
