Gen2 Hemi spark plugs #3061023
07/20/22 04:35 PM
07/20/22 04:35 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Hi guys, I don't come here much anymore so this topic has probably been beat to death but what spark plugs do you prefer for a Hemi. Mine is an aluminum 528 with Indy Legend heads, pump gas compression, 100% street car with a 1040 cfm APD 4150 carb.
I'd prefer a plug that doesn't come with the washers installed if possible. I tried running w/o the washers lately and the tubes seemed to stay cleaner inside that way.
I've been trying the NGK plugs, R5671A-7 and -9. Still doing some carb tuning but wanted to see if there's something else better for the street.
Re: Gen2 Hemi spark plugs [Re: ProSport] #3061058
07/20/22 06:32 PM
07/20/22 06:32 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
On my iron headed 528 the R5671A-7 worked well.
Re: Gen2 Hemi spark plugs [Re: NITROUSN] #3061175
07/21/22 04:13 AM
07/21/22 04:13 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Ok thanks, I'm interested to hear more opinions as well.
It seems like the 7's run richer than the 9's in my car but I'm also tuning the carb so I'll keep playing with it.
Re: Gen2 Hemi spark plugs [Re: ProSport] #3061317
07/21/22 12:40 PM
07/21/22 12:40 PM
The only spark plugs I know of that don't came with gaskets are the tapered seat plugs shruggy
You don't want to use them in any Hemi motors I know of currently: confused:
As far as heat range I like to run the coldest plug I can that runs clean and doesn't get black at light part throttle driving up twocents
On your deal I would try a Champion RN9YC or maybe a Champion race plug. Autolite street plug # 3923 or maybe their 3922. Autolite # 3911 or 3910 on their race plugs.
I'm not current on NGK plug #s blush shruggy
Re: Gen2 Hemi spark plugs [Re: ProSport] #3061332
07/21/22 01:12 PM
07/21/22 01:12 PM
an8sec70cuda Offline
I've always run NGK 4554 plugs (R5671A-8) on pump gas when I run it naturally aspirated. Never bothered to remove the washers.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Gen2 Hemi spark plugs [Re: ProSport] #3061341
07/21/22 01:33 PM
07/21/22 01:33 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I run the autolite AR 3911 - been happy with and I have 8 sets in stock in the garage if you want to try them
Re: Gen2 Hemi spark plugs [Re: Cab_Burge] #3062501
07/25/22 04:47 PM
07/25/22 04:47 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Some plugs have the washer loose in the box so you have to screw it on yourself, that's what I meant.
Doesn't matter, I'll just use the washers, running without them didn't help anything.
Re: Gen2 Hemi spark plugs [Re: an8sec70cuda] #3062502
07/25/22 04:48 PM
07/25/22 04:48 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Ok thanks Chip, I'll try those this week.
Re: Gen2 Hemi spark plugs [Re: DoubleD] #3062503
07/25/22 04:49 PM
07/25/22 04:49 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Thanks Dave, there's only 6 in stock at Summit right now. I'll let you know if I need to buy some from you, I'm gonna try the NGK-4554's first.
Re: Gen2 Hemi spark plugs [Re: ProSport] #3062581
07/25/22 09:49 PM
07/25/22 09:49 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
[i][/i] I first started with 9's and kept going hotter to until I stopped at 6's and stayed there . The 605 runs it's best on 91 octane and #6 plugs.
