Fixing an aluminum radiator, where find low heat welding rod #3061095
07/20/22 09:01 PM
07/20/22 09:01 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
So I have an aluminum race radiator that is in great condition, but somehow got nicked and sprinkle a very small leak in one of the tubes. I think I can fix it with sold aluminum low heat welding rod that melts with a torch. Any sources out there that are good quality? Not sure what is a good and what is crap. We had some we used on transmission cases and work great, but ran out and the source we used has been long closed now.
Re: Fixing an aluminum radiator, where to find low heat welding [Re: migsBIG] #3061096
07/20/22 09:03 PM
07/20/22 09:03 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You should be able to solder it.
Re: Fixing an aluminum radiator, where to find low heat welding [Re: NITROUSN] #3061097
07/20/22 09:09 PM
07/20/22 09:09 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
. Would rather use the rod to solder it as I don’t have a soldering gun or equipment. Plus I’d like to have some for future repairs and last minute repairs.
Re: Fixing an aluminum radiator, where to find low heat welding [Re: migsBIG] #3061111
07/20/22 09:30 PM
07/20/22 09:30 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Most repairs can be done with a simple propane torch.
Re: Fixing an aluminum radiator, where to find low heat welding [Re: NITROUSN] #3061114
07/20/22 09:46 PM
07/20/22 09:46 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
iagree
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Fixing an aluminum radiator, where to find low heat welding [Re: BloFish] #3061118
07/20/22 09:57 PM
07/20/22 09:57 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
might check these guys, their pot metal repair works great LINKY
Re: Fixing an aluminum radiator, where to find low heat welding [Re: TJP] #3061124
07/20/22 10:05 PM
07/20/22 10:05 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Need one that does not use flux. Melt directly to surface and it binds to it. Similar to this:
https://toinspiration.com/products/welding-wire
Re: Fixing an aluminum radiator, where to find low heat welding [Re: migsBIG] #3061133
07/20/22 10:16 PM
07/20/22 10:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Without seeing what you have its hard to say what exactly you are fixing. But if it is what I think I could have it repaired in minutes.
Re: Fixing an aluminum radiator, where find low heat welding rod [Re: migsBIG] #3061155
07/21/22 01:13 AM
07/21/22 01:13 AM
USA
Grizzly69 Offline
Grizzly69  Offline
USA
Re: Fixing an aluminum radiator, where find low heat welding rod [Re: Grizzly69] #3061275
07/21/22 11:06 AM
07/21/22 11:06 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
I found this on Youtube where the test a bunch of no weld welding rods. Pretty interesting results.
Re: Fixing an aluminum radiator, where find low heat welding rod [Re: migsBIG] #3061459
07/21/22 05:31 PM
07/21/22 05:31 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Just put some epoxy into the broken tube & then crimp it over, one tube wont affect its cooling ability
Re: Fixing an aluminum radiator, where find low heat welding rod [Re: CSK] #3061558
07/22/22 08:03 AM
07/22/22 08:03 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
perception is 90% of reality
Re: Fixing an aluminum radiator, where find low heat welding rod [Re: Mr T2U] #3061570
07/22/22 09:36 AM
07/22/22 09:36 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Not sure if it's an option for you but I've tig welded damaged cores many times, no problem.
