Re: Standard exhaust port BB heads
[Re: hemienvy]
#3060490
07/19/22 09:36 AM
07/19/22 09:36 AM
Posts: 1,166 Loudoun County, VA
Brad_Haak
Loudoun County, VA
NOT B1-BS; definitely raised exhaust port, although standard-height intake
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: AndyF]
#3060501
07/19/22 10:30 AM
07/19/22 10:30 AM
fast68plymouth
So. Burlington, Vt.
The current “default” std port head is the TF 240.
Best bang for the $$$.
