Standard exhaust port BB heads #3060395
07/18/22 09:50 PM
07/18/22 09:50 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Thinking of changing 452 heads to something "better" on a 451. Better flow, same intake/exh port locations.
I don't want to change headers.
TFS 240, Edel RPM, maybe even B1BS ?
I'm not that knowledgible on the exhaust port locations.
Re: Standard exhaust port BB heads [Re: hemienvy] #3060400
07/18/22 10:04 PM
07/18/22 10:04 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Also Indy EZ cylinder heads.
Re: Standard exhaust port BB heads [Re: hemienvy] #3060490
07/19/22 09:36 AM
07/19/22 09:36 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
NOT B1-BS; definitely raised exhaust port, although standard-height intake
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Standard exhaust port BB heads [Re: hemienvy] #3060500
07/19/22 10:29 AM
07/19/22 10:29 AM
AndyF Offline
AndyF  Offline
Trick Flow 240 and Trick Flow 270 exhaust ports are very close to stock location but spark plugs are angled. Same with Indy EZ heads. 440 Source heads are same as stock with straight plugs. I think Edelbrock RPM is stock location and angled plugs but they might have a straight plug option also.
Re: Standard exhaust port BB heads [Re: AndyF] #3060501
07/19/22 10:30 AM
07/19/22 10:30 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The current “default” std port head is the TF 240.
Best bang for the $$$.
Re: Standard exhaust port BB heads [Re: fast68plymouth] #3060620
07/19/22 04:34 PM
07/19/22 04:34 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Thank you Gents very much.
