Re: Mopar Madness Dragway 42
[Re: BryanRad]
#3060420
07/18/22 10:29 PM
07/18/22 10:29 PM
Posts: 394 Ohio
moparjoe360.4
Ohio
Curious as to how well attended the subject show is. Thanks in advance. I’m hoping for a Norwalk kind of turn out personally, it is the first year but I feel like it has been well promoted and it’s the same weekend as Monter Mopar would have been if it wasn’t cut and replaced with a tractor pull.
[Re: moparjoe360.4]
#3060430
07/18/22 11:35 PM
07/18/22 11:35 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Curious as to how well attended the subject show is. Thanks in advance. I’m hoping for a Norwalk kind of turn out personally, it is the first year but I feel like it has been well promoted and it’s the same weekend as Monter Mopar would have been if it wasn’t cut and replaced with a tractor pull. Your information regards why Monster Mopar didn’t happen at Norwalk this year had nothing to do with the tractor pull. Zilch, zip, nothing. The Mopar event is planned to be supported at Norwalk and promoted by the track itself next year.
[Re: B3422W5]
#3060445
07/19/22 12:53 AM
07/19/22 12:53 AM
Posts: 394 Ohio
moparjoe360.4
Ohio
Curious as to how well attended the subject show is. Thanks in advance. I’m hoping for a Norwalk kind of turn out personally, it is the first year but I feel like it has been well promoted and it’s the same weekend as Monter Mopar would have been if it wasn’t cut and replaced with a tractor pull. Your information regards why Monster Mopar didn’t happen at Norwalk this year had nothing to do with the tractor pull. Zilch, zip, nothing. The Mopar event is planned to be supported at Norwalk and promoted by the track itself next year. I was just stating it at face value, I figured there was a lot more at play than that, and I have been hearing rumblings of the track putting on their own Mopar event next year as well, am I a bit salty that an event I have been going to since it started isn’t happening this year yes, do I think the last few promoters of the event have done it any favors, no. That being said I truly hope the track takes it over, I will most definitely support it, I made my first pass ever at that event when it was the Chrysler Classic almost 20 years ago.
[Re: B3422W5]
#3060466
07/19/22 07:29 AM
07/19/22 07:29 AM
Posts: 4,696 On the parachute mount
n20mstr
Curious as to how well attended the subject show is. Thanks in advance. I’m hoping for a Norwalk kind of turn out personally, it is the first year but I feel like it has been well promoted and it’s the same weekend as Monter Mopar would have been if it wasn’t cut and replaced with a tractor pull. Your information regards why Monster Mopar didn’t happen at Norwalk this year had nothing to do with the tractor pull. Zilch, zip, nothing. The Mopar event is planned to be supported at Norwalk and promoted by the track itself next year. will they be running the same classes at Norwalk ? You know what im looking for , KOS
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3060471
07/19/22 08:17 AM
07/19/22 08:17 AM
Posts: 394 Ohio
moparjoe360.4
Ohio
Curious as to how well attended the subject show is. Thanks in advance. I’m hoping for a Norwalk kind of turn out personally, it is the first year but I feel like it has been well promoted and it’s the same weekend as Monter Mopar would have been if it wasn’t cut and replaced with a tractor pull. Your information regards why Monster Mopar didn’t happen at Norwalk this year had nothing to do with the tractor pull. Zilch, zip, nothing. The Mopar event is planned to be supported at Norwalk and promoted by the track itself next year. will they be running the same classes at Norwalk ? You know what im looking for , KOS They have KOS listed so Hopefully they have enough guy’s show up to run it that they have a class.
[Re: dvw]
#3061144
07/20/22 11:09 PM
07/20/22 11:09 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I'll be there it's only half hour from my house. Looks like it's gonna be a cooker. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: cudaboy]
#3062188
07/24/22 07:07 PM
07/24/22 07:07 PM
fourgearsavoy
Rittman Ohio
Had a great time and the turn out was pretty good. We did have a couple issues with the weather on Saturday but it dried up and racing resumed. I will go back to the D42 show again next year. That track always has a family atmosphere and it feels good to be there. Gus
[Re: fourgearsavoy]
#3062373
07/25/22 11:51 AM
07/25/22 11:51 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Found this on Facebook today
[Re: pittsburghracer]
#3062431
07/25/22 02:02 PM
07/25/22 02:02 PM
Posts: 9,871 MI, usa
dvw
MI, usa
My weekend was fun. Great to see a lot of people that I missed last year. Weather was a challenge with varying wind speed, and direction. Not to mention D/A up to 4300+. Car was very good. Slowed it to run 9.25. Took quite a bit of ballast. Last two qualifiers we went 9.256, 9.255. The 60 ft grouping with ballast over 7 runs Saturday and Sunday varied best to worst by .011. And that is foot braking with no rpm chip. The driver R/T wasn't as good. After 7 passes with the exception of a ok .031 I was stuck between .043 -.055. 1st rd was .021 had the guy by a bunch and lifted. My prediction was off by about .025. Looked like we had a 4-6 mph direct head win for a 13 minute period during that run time. Rd 2 I built in .015 for wind. By looking at data this time the head gusts stopped about 2 minutes before the run. Car ran 9.234. Unfortunately the driver was -.003. Track prep was good. Event ran in a timely manner. What didn't I like? Friday $40 6 pm - 10 pm T&T the guy says 3 runs only. I ask why ? He says to many cars. But wait. We have time to add an unscheduled gamblers race for another $50. Can I test during the gamblers? No. Then the next day I'm told that there was testing. The 2nd item is one race over a weekend. 180 miles one way for one race at $150 + $50 for Saturdays gambler +40 for Friday. Vs payout. Not the best value. Doug
[Re: fourgearsavoy]
#3062478
07/25/22 03:31 PM
07/25/22 03:31 PM
Posts: 2,117 Cleveland Ohio
10secGTX
Cleveland Ohio
I'll be there it's only half hour from my house. Looks like it's gonna be a cooker. Gus Thank You to Gus and Russ for your help, truly a great time. Turnout was over 200 cars … with the help and input of racers this could be a greater event PS we had to duck a lot of gun fire between rounds and the amount of cash changing hands on starting line caused us to have a Brinks Truck bring more money
