Re: Speedmaster alum. SB heads
[Re: LSP]
#3060046
07/17/22 10:20 PM
07/17/22 10:20 PM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Looks similar to the Edelbrock head, any differences?
Anything to be wary of?
Can handle a 2.080" intake valve?
Thanks Yes it can. Is it easy to make a 2.08 valve pay dividends, no. But a ProMax, Speedmaster, Edelbrock head can be made to flow in the 320cfm area.
[Re: forphorty]
#3060141
07/18/22 11:11 AM
07/18/22 11:11 AM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The biggest area for concern would be to make sure the rocker stands have the correct radius to properly fit the shafts.
Sometimes it’s an issue with those.....sometimes it’s not.
