Dodge dealer tech questions #3057977
07/10/22 01:26 PM
07/10/22 01:26 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
I just finished rebuilding the 360 in a 1999 Dakota. We used a scan tool to sync the base timing and it fired right up first try. Runs great, no leaks. Took for a test spin seemed sluggish like taking off in high gear. Hooked scan tool back up and it does show trans is stuck in 3rd gear. Has all of these error codes. Tried to clear them but they come right back.
Odd thing is transmission was not touched. It was supported with trans jack during the rebuild of engine. Didn't touch anything on the trans other than bellhousing and torque converter bolts.
None of these issues or codes were present before engine swap.
How would doing an engine swap cause all these transmission codes?
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Dodge dealer tech questions [Re: 6PKRTSE] #3057980
07/10/22 01:35 PM
07/10/22 01:35 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Double check all your connectors are seated. Hands on check, not an eyeball. Ran into something similar and it turned out to be a connector not fully seated, but to the eyeball it looked ok
Re: Dodge dealer tech questions [Re: Sniper] #3058002
07/10/22 03:45 PM
07/10/22 03:45 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
iagree
Re: Dodge dealer tech questions [Re: 6PKRTSE] #3058007
07/10/22 04:31 PM
07/10/22 04:31 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Check all your grounds and connectors. Disconnect the battery, press the brake and hold it and turn the key to On & then Start for 2 to 3 seconds while doing this, then restore and recheck.
There used to be a sharp Tech at Solo PCM's in Florida who may know what's going on if the above doesn't work. Best of luck.
Re: Dodge dealer tech questions [Re: jbc426] #3058362
07/11/22 07:00 PM
07/11/22 07:00 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
If your first check of grounds and connectors doesn't solve the problem, physically trace the wiring from the PCM to the trans to make sure nothing was damaged during the swap. Next step would be getting a diagram and checking resistance on the wiring from those solenoids to the PCM...
Re: Dodge dealer tech questions [Re: 6PKRTSE] #3058378
07/11/22 07:51 PM
07/11/22 07:51 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
Also take a good look to make sure you didn't pinch any wires between the engine a trans.
Re: Dodge dealer tech questions [Re: Fat_Mike] #3058397
07/11/22 09:24 PM
07/11/22 09:24 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
All good suggestions beer
Re: Dodge dealer tech questions [Re: TJP] #3058467
07/12/22 12:00 AM
07/12/22 12:00 AM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
It got dark on me on Saturday night. I will try to look at it again tomorrow after work. Thank you all for the suggestions.
