A/C Component Storage #3057699
07/09/22 03:47 PM
07/09/22 03:47 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
I''m looking at removing the A/C from a '74 Roadrunner for a future re-installation. What are the procedures to store a compressor, evaporator, condenser, hoses, etc. etc. in the interim?
Re: A/C Component Storage [Re: 6PakBee] #3057759
07/09/22 07:44 PM
07/09/22 07:44 PM
Andrewh Offline
Andrewh  Offline
if it has a dryer, I think that is the only thing that needs to be "sealed" the rest of the parts just need to be capped to keep critters out of it.
new parts do have tighter seals on the compressor, because they pre-oil so it doesn't come out. but just plastic press fit caps on everything else.
Re: A/C Component Storage [Re: Andrewh] #3057917
07/10/22 10:24 AM
07/10/22 10:24 AM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Thanks for the reply. When you go back together, what is the cleaning procedure for components other than the compressor and the dryer, blow out with air, flush with some kind of solvent, ???
Re: A/C Component Storage [Re: 6PakBee] #3057974
07/10/22 01:14 PM
07/10/22 01:14 PM
moparx Offline
moparx  Offline
if it were me, i would just replace the drier. they are cheap insurance for the whole system.
i think there is a flush product you can blow through the lines to clean them out.
beer
Re: A/C Component Storage [Re: moparx] #3057976
07/10/22 01:21 PM
07/10/22 01:21 PM
Andrewh Offline
Andrewh  Offline
I don't know that you need to.
typically a flush is required due to damage and gunk pushed into the system.
but for piece of mind denatured alcohol is typically what is used.
be aware, then you have to figure out how much oil got removed and add that back into the system.
Re: A/C Component Storage [Re: Andrewh] #3058000
07/10/22 03:36 PM
07/10/22 03:36 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Thanks to both of you, this was very helpful. up
Re: A/C Component Storage [Re: 6PakBee] #3058008
07/10/22 04:41 PM
07/10/22 04:41 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
6PakBee,
It would be best to seal up all components to prevent moisture infiltration. Moisture is the refrigerant system’s enemy. I also would replace the drier as I believe it is necessary whenever you open the system for more than an hour. Additionally, pulling a good vacuum for a couple hours after verifying no leaks is good practice using a good vacuum pump.
Ron
Re: A/C Component Storage [Re: 6PakBee] #3058023
07/10/22 05:33 PM
07/10/22 05:33 PM
Guitar Jones Offline
Mine was apart for 3 years. I taped the compressor and condenser. I replaced the H valve, drier, and evaporator. I drained the oil from the compressor and condenser then filled it with the required 6.4 oz. The lines were kept in a sealed bin. I vacuumed it for 2 hours, charged it and it's been working great.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: A/C Component Storage [Re: Guitar Jones] #3058606
07/12/22 03:03 PM
07/12/22 03:03 PM
moparx Offline
moparx  Offline
when i pull a vacuum on a system, i have a ball valve that i close, then monitor the system for loss of vacuum.
if no loss, then proceed to charge.
if vacuum drops, it's time to find the leak.
beer
