Disposal of old gas? #3057693
07/09/22 03:28 PM
07/09/22 03:28 PM
Moved to N.E. Tennessee
GomangoCuda Offline OP
I have a couple of gallons of old gas that I syphoned out of a car I let sit for a couple years due to a dead in tank pump. Probably more after I drop the tank. What is the best way to dispose of a few gallons? I don't really trust it to use in lawn equipment.
Re: Disposal of old gas? [Re: GomangoCuda] #3057696
07/09/22 03:40 PM
07/09/22 03:40 PM
A727Tflite Offline
A727Tflite  Offline
Bring a gallon at a time and when almost empty add it to the tank of your driver then top it off with fresh fuel. Do it all the time.
As long as there is no water in it or rust.
Re: Disposal of old gas? [Re: GomangoCuda] #3057703
07/09/22 04:02 PM
07/09/22 04:02 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
See if your town has a hazardous waste drop off center.
If you're rural, light your burn barrel with it. Just but be careful of your ignition technique!
Re: Disposal of old gas? [Re: Fat_Mike] #3057708
07/09/22 04:24 PM
07/09/22 04:24 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
Great for weeds in the driveway or to mix with old motor oil to brush on exposed wood to keep it solid.
STOP POTATO HATE!
Re: Disposal of old gas? [Re: Mr PotatoHead] #3057709
07/09/22 04:30 PM
07/09/22 04:30 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
It's pretty effective on weeds and fire ants, or so I've heard........ wave
Re: Disposal of old gas? [Re: bobby66] #3057735
07/09/22 06:38 PM
07/09/22 06:38 PM
md
mopars4ever Offline
mopars4ever  Offline
md
The landfill near me takes old gas. Maybe check your area for disposal.
Re: Disposal of old gas? [Re: mopars4ever] #3057742
07/09/22 06:49 PM
07/09/22 06:49 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If you burn it use a big open container with a long fuse, it goes up fast. or spray on weeds
Re: Disposal of old gas? [Re: GomangoCuda] #3057819
07/09/22 11:08 PM
07/09/22 11:08 PM
Mix it in with some of your waste engine oil after changing it, 1 gallon to 4 gallons in a 5-gallon oil can up
Take it to your local oil recycler and get paid boogie scope
Re: Disposal of old gas? [Re: Cab_Burge] #3057830
07/09/22 11:50 PM
07/09/22 11:50 PM
MI
I
IROC78 Offline
IROC78  Offline
I
MI
There's a couple of shops near me that heat their buildings with waste oil during the winter. I bring them all of my used oil and they take old gas as well. Maybe someone near you has a similar setup and could use it to heat their shop.
Re: Disposal of old gas? [Re: IROC78] #3057837
07/10/22 12:09 AM
07/10/22 12:09 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
That would be bon fire starter for me. Week or so and it would be gone
Re: Disposal of old gas? [Re: bobby66] #3057840
07/10/22 12:36 AM
07/10/22 12:36 AM
Hypothetically,.if I sprayed the weeds in the gravel drive that goes back to my shop how long would it smell and be flammable? Would hot headers catch it on fire hours or days later? Would neighbors smell it and call police or fire?
Re: Disposal of old gas? [Re: GomangoCuda] #3057898
07/10/22 08:36 AM
07/10/22 08:36 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
If your neighbors are that close there's a good chance you have a waste collection point nearby.
Re: Disposal of old gas? [Re: GomangoCuda] #3057909
07/10/22 09:59 AM
07/10/22 09:59 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Old Coleman brand name camping stoves
can safely burn up unleaded gasoline in a legal way.
Coleman made a little funnel with a built in filter to fill their stove fuel tank.
If you do this regularly
adding an ounce of Chevron Techron or Regane gasoline fuel injection additive
to the stove fuel tank will help keep the burner holes free of carbon build up.
There are gasoline/oxygen steel cutting torches too.
Re: Disposal of old gas? [Re: Mr PotatoHead] #3057913
07/10/22 10:14 AM
07/10/22 10:14 AM
IMGTX Offline
IMGTX  Offline
What I don't use in this way I give to my brother in law for the same purpose.
Re: Disposal of old gas? [Re: GomangoCuda] #3057914
07/10/22 10:20 AM
07/10/22 10:20 AM
IMGTX Offline
IMGTX  Offline
Never had a neighbor call anyone and the smell will dissipate in a matter of 5 or 10 minutes if it doesn't form a puddle. Drove over it after a few minutes while I could still smell it and no problems.
If you have neighbors that are that picky you need new neighbors. LOL
Re: Disposal of old gas? [Re: IMGTX] #3057926
07/10/22 11:11 AM
07/10/22 11:11 AM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I also do what Transman does
Re: Disposal of old gas? [Re: Dcuda69] #3057951
07/10/22 11:57 AM
07/10/22 11:57 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I had a 1/2 tank of who knows how old of gas in a /6 truck I bought a couple of years ago, I just let it run out in the gravel drive.
(Currently my "project truck")
Just this past week I dragged home a rotted out 91 Dakota with a supposed dead fuel pump. I parted it out, and scrapped it. Including cutting the tank straps and saving a whole tank of gas. I siphoned off what I could then poured the last gallon or so out, into one of my 5 gallon cans/ filled my mowers, filled the wife's Durango, and still have about 10 gallons of it left. At $5 a gallon it won't go to waste.
Several years ago I dragged home a 76 Aspen from several states away.
Now that gas was way too rancid to consider trying to burn.
As was the gas left in the tank I found in the junkyard for my son's truck, I poured that out in the gravel and smelled that for over a week.
Any gas not as rancid as those 2 or full of water gets burned in another vehicle whether a gallon or 2 at a time diluted with a fresh fill, or to completely top off one of our drivers
Good tip on additives to the Coleman stoves. I'm up to about 18 lanterns now and about 8 Coleman stoves. I had a dozen lanterns lit yesterday on the bed of my truck yesterday, I always have 3 or 4 stashed in the Pop up at any given time.
It's funny when I camp and hear people who walk by and I hear them ask"people still use those?" He11 yeah I do
Re: Disposal of old gas? [Re: GomangoCuda] #3057959
07/10/22 12:20 PM
07/10/22 12:20 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
You have some left over after washing parts?
Re: Disposal of old gas? [Re: IMGTX] #3057991
07/10/22 02:12 PM
07/10/22 02:12 PM
Actually I have great neighbors who have never complained about anything and I want to keep it that way.
Re: Disposal of old gas? [Re: GomangoCuda] #3058174
07/11/22 11:00 AM
07/11/22 11:00 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
I have 6 year old cali oat pisss in my cuda tank that's going to need to be drained to. I think I know what I'm going to do with it.
ozbbq
