Plugs for a 496 with stage 6 alum heads, also tuning MSD
#3057495
07/08/22 08:20 PM
07/08/22 08:20 PM
Posts: 1,898 Milwaukee WI
R_Blaha
Milwaukee WI
Question, I'm going to change the plugs on my dad's car and I was just wondering what plug is everyone using with the stage 6 aluminum heads? The motor is a stroked 440 from muscle motors that is 496ci, 10.5 to 1 comp, with a 850 double pumper demon carb, and backed by a 727. I think he has Champions in there now, not sure if they are the RN12YC's or not.
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT 1969 Dodge Superbee post coupe 383 1969 Dodge Superbee hardtop 472 hemi 1989 Mustang GT 1993 mustang lx 5.0 2004 screaming yellow cobra 2013 CVO Roadglide
Re: Plugs for a 496 whith stage 6 heads
[Re: R_Blaha]
#3057516
07/08/22 09:22 PM
07/08/22 09:22 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
Autolite 3924 Maybe a Champion RC9YC Your way better off running a colder plug than the motors needs versus to hot If the car sits a lot between uses it may have a fuel quality issue when the gas in the fuel tank gets older than 90 days if it does sit a lot drain it and use that gas in some other newer vehicle with knock sensors and put new fresh gas in it to help not hurt itself
[Re: rebel]
#3057577
07/09/22 12:43 AM
07/09/22 12:43 AM
Cab_Burge
[Re: Cab_Burge]
#3057588
07/09/22 04:46 AM
07/09/22 04:46 AM
Posts: 4,647 aotearoa
rebel
aotearoa
[s][/s] Wow thats really anal.
[Re: R_Blaha]
#3058336
07/11/22 05:45 PM
07/11/22 05:45 PM
R_Blaha
Milwaukee WI
So I talked to my dad and he changed the plugs over winter to a RJ18YC Champions. The car was running super rich with the 850 demon and I messed with the MSD distributor at first timing was 18 degrees at idle 36 advanced with lite springs and pulling 9-10 inches in vacuum. Changed out the spacer for the advance so now timing is 28 degrees idle and 36 degrees advanced and the car runs way better now with an idle around 850-900rpm pulling about 12 inches of vacuum, car drives like a new car, no kidding. Now my question is should I run the colder plug and my buddy says since my dad is running a digital 7 box we could lock out the distributor for 36 degrees at idle and retard the timing on the msd box. Would running a colder plug with the timing locked out would that make a big difference running and performance wise? We also mix a combo of non reformulated 91 fuel with leaded 110 race fuel. Also this car doesn't have any vaccuum advance or power brakes.
