Re: DOT 5 Brake Fluid
[Re: DAYCLONA]
#3057081
07/07/22 11:40 AM
07/07/22 11:40 AM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Yes, although DOT5 is often advertised as being non-hygroscopic (not moisture-absorbing) it will absorb a tiny amount of moisture (on the order of 280 parts per million, or .0028%) and then absorb no more.
[Re: DAYCLONA]
#3057082
07/07/22 11:41 AM
07/07/22 11:41 AM
Posts: 11,552 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Absorb? No. That doesn't mean moisture won't get into the system through contamination, humidity, etc.
DOT 3 and 4 will absorb water. Dot 5 will not. Instead it allows it to settle in the system and cause corrosion. Another reason I don't use it in race cars where systems are (or should be) maintained regularly..
[Re: CMcAllister]
#3057087
07/07/22 11:52 AM
07/07/22 11:52 AM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
No, dot 5 will not absorb moisture. I've had it in my olds for over 40 years. Sometimes the car sits for years un used. I live in an area where it can get very humid in the summer. I have never had an issue with anything in the brake system rusting, seizing, leaking, or any other type of failure. I pulled the car out of 23 years of storage, and the brakes were still fine.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: TJP]
#3057582
07/09/22 01:42 AM
07/09/22 01:42 AM
Posts: 1,821 South Bend
John Brown
South Bend
FWIW, with Dot 5, whatever moisture may be in the system accumulates in little pockets instead of being easily absorbed by the fluid. Maybe it just picked your brake valve as a place to collect.
