pre 72 post 73 A body Iddle and pitman arms #3056144
07/05/22 10:29 AM
07/05/22 10:29 AM
Valencia, España
NachoRT74 Offline OP
Valencia, España
Aside the 73 and lates 4 keys feature on the pitman arms is there another difference between these pieces? geometry ?
why the iddler arm would change too ?
I can see a PN change on these parts between pre 72 and post 73
Re: pre 72 post 73 A body Iddle and pitman arms [Re: NachoRT74] #3056164
07/05/22 10:45 AM
07/05/22 10:45 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The center link changed 73-76. The 73-76 center links take pitman arm and idler arm that attach from on top.
Also the 73-up power steering boxes are larger spline diameter. So that pitman changed the spline diameter and it mounts from the top.
The overall geometry is the same 67-76. So you can swap certain groups of parts as a unit.
In my 68 Barracuda, I swapped to a large spline power steering box because is was the only style Mopar sold remanufactured. So I had to swap to a 73-76 centerlink (top mount), large spline pitman (top mount), and idler (top mount). Later, I swapped my K-member to 73-76 style. Also at that time I swapped my lower control arm, strut rods, and sway bar to the 73-76 style.
Re: pre 72 post 73 A body Iddle and pitman arms [Re: autoxcuda] #3056228
07/05/22 12:36 PM
07/05/22 12:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The over all geometry is the same 67-76. So you can swap certain groups of parts as a unit.
This , I found this out the hard way when I put a new steering box in my dad's 72 duster , luckily you could still find the centerlink was still found in the junkyard .
Re: pre 72 post 73 A body Iddle and pitman arms [Re: autoxcuda] #3056518
07/06/22 03:40 AM
07/06/22 03:40 AM
Valencia, España
Valencia, España
I thought the indexing of the Pitman and iddler arms pivots from top to bottom was changed between 66 and 67 and not 72 and 73!... ok nice to know.
Re: pre 72 post 73 A body Iddle and pitman arms [Re: NachoRT74] #3058765
07/13/22 03:30 AM
07/13/22 03:30 AM
lyon
fdax Offline
fdax  Offline
lyon
I was just trying to confirm my pitman arm is bad cause I saw it moving a lot... and this helped me verify. Also liked how you showed the tie rod with the bad boot but there was no play so it’s good, that’s awesome.
192.168.100.1 192.168.1.1
