1970 Dart Swinger Bumble Bee Stripe #305536
05/02/09 03:48 PM
05/02/09 03:48 PM
Ms.
Dartwizer Offline OP
Ms.
Trying find the placement for the Bumble Bee stripe, ie. the distance from the bumper, fender edge,to the start of the stripe......thanks
Re: 1970 Dart Swinger Bumble Bee Stripe [Re: Dartwizer] #305537
05/02/09 05:06 PM
05/02/09 05:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The side marker light opening should determine where it goes I'm guessing.
Re: 1970 Dart Swinger Bumble Bee Stripe [Re: Neil] #305538
05/02/09 05:51 PM
05/02/09 05:51 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
The stipes I installed werent cut for the marker lights. I can try and post a picture later however Im having computer issues. If you put them up to the car you should be able to get them pretty close anyways. Start with the sides then do the lid last.
Re: 1970 Dart Swinger Bumble Bee Stripe [Re: AdamR] #305539
05/02/09 06:34 PM
05/02/09 06:34 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
So you have to go back and trim around the lights with an x-acto blade? Why don't they just pre-cut the holes in the first place?
Re: 1970 Dart Swinger Bumble Bee Stripe [Re: Dartwizer] #305540
05/02/09 07:00 PM
05/02/09 07:00 PM
Ms.
Ms.
Thanks Guys,went back to the shop and placed them on the car.Used the body line on the rear of the fender as a guide.Thank you for your response,,,,Dartwizer
Re: 1970 Dart Swinger Bumble Bee Stripe [Re: Dartwizer] #305541
05/02/09 11:40 PM
05/02/09 11:40 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
Here's mine, but can't swear that's correct.
Re: 1970 Dart Swinger Bumble Bee Stripe [Re: 70challrtse] #305542
05/02/09 11:57 PM
05/02/09 11:57 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Here is how we did my sons 72 Dart. I looked at alot of darts and it looked that the stripe was about as wide as the side marker and went right over the marker light and was even with the light. Ron
