Hurst shifter #3055278
07/02/22 03:25 PM
07/02/22 03:25 PM
Lethbridge, AB, Canada
dangina Offline OP
dangina  Offline OP
Has anyone used the new Hurst competition plus shifter for their 71 bbody? I noticed on the brewers performance website it says will not work for 71-74 bbody but not sure why.
Likes/dislikes?
https://www.holley.com/products/dri...ccessories/manual_shifters/parts/3914076
Re: Hurst shifter [Re: dangina] #3055299
07/02/22 05:02 PM
07/02/22 05:02 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
The 71-74 B bodies have a lot of similarities with E bodies. Shifter may be one. The levers on the bottom of the E body shifter body are offset differently than other shifters. That said, I have a Gm style Hurst Super Shifter2 in my E body and even though the levers are not offset the same as a stock shifter it fits and works as it should without any modifications using the original E body shifter mount instead of the corvette mount that came with it. Obviously your experience may differ when mixing up parts.
Re: Hurst shifter [Re: dangina] #3055321
07/02/22 06:49 PM
07/02/22 06:49 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The difference would be that if it's a bucket seat 71 B-Body it would use the same shifter as an E-Body.
If it's a a bench seat 71 B-Body it takes a special shifter.
The link you posted looks like it's intended for 70 and prior B-Bodies.
This pics shows the different shifter mounting locations.
The top one is A-Body.
The lower one shows the two different mounting locations used by B&E Bodies.
70 and prior B-Bodies use the front one, closest to the main body of the trans.
71 bench seat B-Bodies use that location also with a special shifter mounting bracket and shifter.
E-Bodies and bucket seat 71 up B-Bodies use the location at the rear of the tail housing.
Re: Hurst shifter [Re: SNK-EYZ] #3055377
07/02/22 10:51 PM
07/02/22 10:51 PM
VA
dragon slayer Offline
VA
I thought the brewer site meant with original rods. I think you have to use inserts with Mopar rods because lever holes are larger.
Re: Hurst shifter [Re: SNK-EYZ] #3055416
07/03/22 08:36 AM
07/03/22 08:36 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
There’s one more tail shaft used on the 66 b-bodies, trans mount is different
Re: Hurst shifter [Re: dangina] #3057254
07/07/22 07:04 PM
07/07/22 07:04 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
The levers are what make them specific to certain makes/models. The new 4076 Hurst has levers comparable to the 68-9 B, and the 68-74 A with 6353 rev lever.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
