Balance holes in outer ring of harmonic damper? Thoughts? #3054749
06/30/22 07:10 PM
06/30/22 07:10 PM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
I recently sold a big block harmonic damper to a guy and was told it was no good as it had a hole drilled in the outer ring (similar to the attached image). My beleif was / is this was done at the factory and with as many examples as I have seen I never suspected it to be problematic. Am I wrong? I certainly don't want to dissapoint a buyer and you learn something new everyday so here I am asking. Appreciate your guys help! beer
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Balance holes in outer ring of harmonic damper? Thoughts? [Re: MadMopars] #3054753
06/30/22 07:23 PM
06/30/22 07:23 PM
Chicago
PurpleBeeper Offline
Chicago
Those holes look normal to me. I've never studied them, but I think all my stock balancers have them
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Balance holes in outer ring of harmonic damper? Thoughts? [Re: MadMopars] #3054754
06/30/22 07:23 PM
06/30/22 07:23 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
I was a machinist for 10 years. I balanced a lot of engines. I drilled holes in the outer ring of the damper without any problems. You don't want to go super deep, tough. How deep is the hole?
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: Balance holes in outer ring of harmonic damper? Thoughts? [Re: MadMopars] #3054767
06/30/22 08:09 PM
06/30/22 08:09 PM
N
NITROUSN Offline
NITROUSN  Offline
N
For an accurate opinion you need to post a picture of the damper in question.
Re: Balance holes in outer ring of harmonic damper? Thoughts? [Re: PurpleBeeper] #3054773
06/30/22 08:44 PM
06/30/22 08:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree Unless yo're referring to a 400 or later 440 cast crank balancer
LINKY 1 FIXED LINK smile FYI 2nd one shown has pretty deep hole in outer ring
LINKY2
LINKY 3
Re: Balance holes in outer ring of harmonic damper? Thoughts? [Re: NITROUSN] #3054825
06/30/22 11:30 PM
06/30/22 11:30 PM
Tucson AZ,
Tucson AZ,
Here ya go. scope
Re: Balance holes in outer ring of harmonic damper? Thoughts? [Re: MadMopars] #3054828
06/30/22 11:52 PM
06/30/22 11:52 PM
Tucson AZ,
Tucson AZ,
For what it's worth, the other five I have on the shelf are drilled as well. Come to think of it, I'm not sure I recall ever seeing one that wasn't drilled. work
Re: Balance holes in outer ring of harmonic damper? Thoughts? [Re: MadMopars] #3054862
07/01/22 08:48 AM
07/01/22 08:48 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Send the buyer your photos and tell him to use a better informed machinist.
Re: Balance holes in outer ring of harmonic damper? Thoughts? [Re: NITROUSN] #3054878
07/01/22 09:38 AM
07/01/22 09:38 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The last engine I had balanced came back with new balance holes drilled in the face of the outer ring.
Re: Balance holes in outer ring of harmonic damper? Thoughts? [Re: 6PakBee] #3054933
07/01/22 12:51 PM
07/01/22 12:51 PM
Cab_Burge Online work
Cab_Burge  Online Work
The outer ring is not the best place to drill holes, it can and will spin after enough age and use tsk
The hub is probably the best choice on balance drilling but what do I know whistling
Re: Balance holes in outer ring of harmonic damper? Thoughts? [Re: NITROUSN] #3055104
07/02/22 12:12 AM
07/02/22 12:12 AM
Tucson AZ,
Tucson AZ,
I let him know that it was typical and should be good to go. I told him if he wasn't comfortable using it though he was welcome to send it back and I would refund the purchase price. He says he ordered another one about the same time he bought mine and would compare them and decide from there. I can't imagine the other one is going to be any different but who knows. I can only do so much. Thanks for the input and support. I appreciate it. beer
Re: Balance holes in outer ring of harmonic damper? Thoughts? [Re: MadMopars] #3055174
07/02/22 10:39 AM
07/02/22 10:39 AM
moparx Offline
moparx  Offline
the only thing i can think of, was this damper balanced to a certain crank at one point in time ?
if so, was it balanced to be neutral ? [used with any crank] or was the crank and damper balanced as an assembly ? the damper possibly be off, used on a different crank ?
beer
