champion radiators, recore? #3054198
06/28/22 08:38 PM
06/28/22 08:38 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
has anyone ever had a champion radiator recored?
is it even possible?
i got a hole in one, and replacements are back ordered
Re: champion radiators, recore? [Re: mcat4321] #3054261
06/29/22 05:04 AM
06/29/22 05:04 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
ow big a hole
propane touch and some aluma weld , works good on a/c lines .
Re: champion radiators, recore? [Re: mcat4321] #3054270
06/29/22 07:25 AM
06/29/22 07:25 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I have one that has been repaired. I used an electric fan and didn't use the foam spacers between the core and the fan. After a handful of years it rubbed a pin size hole in the bottom edge of a 2 tubes. I had it repaired by Moparacer. He used some type of epoxy I think and basically bypassed those tubes. It's been like that for probably 7-8 years and I haven't had any issues. I was smart enough when I put it back in to make a mounting bracket from aluminum angle iron to mount the fan to so it doesn't touch the radiator at all.
