Opinion
#3054121
06/28/22 03:32 PM
06/28/22 03:32 PM
Posts: 201 Texas
Chief
Texas
Has anyone used a reground camshaft? Did it last as far as wear?
I have a couple of cams that the lifter failed on and they were hurt, one may be fixed with a regrind but the other has a chunk out of it and will need to be welded. So what is the consensus?
These are billet roller cams.
Dave Covey
Re: Opinion
[Re: stumpy]
#3054124
06/28/22 03:37 PM
06/28/22 03:37 PM
Posts: 201 Texas
Chief
Texas
I talked to Oregon Cams and they charge 199.00 These cams cost 600.00 new.
Not to mention if cores are available.
Dave Covey
Re: Opinion
[Re: Chief]
#3054127
06/28/22 03:40 PM
06/28/22 03:40 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I've used reground roller cams in GM LS engines and haven't had any issues. Haven't done one in several years, but there was a guy on ebay selling factory cams that were reground into a copy of the GM "hot cam" and some other grinds.
Re: Opinion
[Re: NITROUSN]
#3054154
06/28/22 04:51 PM
06/28/22 04:51 PM
Posts: 4,743 Moved to N.E. Tennessee
GomangoCuda
It's going to have a smaller base circle which could be an issue if you already have a big cam with a small base circle. I was told this by one of the major cam companies back in the mid 70's when I asked about regrinding a .770 lift Super Stock cam to a slightly different profile.
Re: Opinion
[Re: Chief]
#3054156
06/28/22 05:04 PM
06/28/22 05:04 PM
Posts: 6,299 nowhere
Sniper
nowhere
Dave Delta Cams can weld them up, regrind them, heat treat them and so on. I suspect any good cam regrinder will do the same. Ask them for the answer. https://deltacam.com/services/camshaft-grinding/As for zinc in the oil, the flatheads don't really care, they have minimal valve spring pressures. A monster cam with battleship springs, yeah you're going to need zinc and such.
Re: Opinion
[Re: topside]
#3054173
06/28/22 05:55 PM
06/28/22 05:55 PM
Sniper
nowhere
^^^ My point was that camshafts & lifters/followers back then had a much easier life. With much crappier oil and filtration though. My feeling is that valve spring pressures are more important than it being a flat tappet setup.
Re: Opinion
[Re: cudaman1969]
#3054179
06/28/22 06:42 PM
06/28/22 06:42 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
I had Bullet regrind a solid roller can to to a different spec and it worked out fine.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
