sure buy a 80-83 cordoba/mirada they said #3052391
06/22/22 12:25 PM
06/22/22 12:25 PM
my own world
theraif Offline OP
theraif  Offline OP
my own world
one thing i knew was the quarter panel pieces would be not a easy find , this is my 1st j-body i knew they changed the front from long t-bars to a criss cross system grin so having some work done to it and found (see photo) this , and that set up is for the smooth ride and comfort that the new 1982 chrysler cordoba can give you..............till 2022 when it broken and spend like an hr google`n and stuff to find a new one hammer so good thing firm feel inc. has a delete kit that gives you the old school set up penguin
Re: sure buy a 80-83 cordoba/mirada they said [Re: theraif] #3052399
06/22/22 12:39 PM
06/22/22 12:39 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Yikes, that must've seen some snow/salt!
I agree, so thankful for firmfeel and all their good stuff!
Facts are stubborn things.
Re: sure buy a 80-83 cordoba/mirada they said [Re: theraif] #3052403
06/22/22 12:48 PM
06/22/22 12:48 PM
Crook County, ILL
Mastershake340 Online content
Mastershake340  Online Content
Crook County, ILL
Some of these cars are a labor of love to restore or fix due to lack of parts availability.
I have been an E body guy forever and have come to take it for granted parts availability as you can damn near build a complete cuda or Challenger from scratch using repro parts. Just add VIN!
I bought a Magnum last year and not long after I topped the gas tank for its winter hibernation I noticed a gasoline smell in the garage every time I went in there. After crawling all over both my Challengers also parked there and finding everything dry as a bone, I noticed some stains under the rear of the Magnum and although I couldn't get under it very well to see exactly where it was leaking from due to how it was wedged into the garage, I could tell it was gas. That is where the odor was from and my tank must be leaking. So I checked online to see what a new gas tank would cost. Last time I bought a tank was 4 or 5 years earlier for my '71 Challenger, and Rock Auto had a new Quanta tank on my doorstep in a couple days for something like $135.
I check Magnums in Rock Autos site , no tanks listed, same tank as Cordoba so next I check Cordoba gas tanks. They made a million of those so surely tanks still available right? No tanks listed anywhere.
Fortunately after I was able to get further under the rear of the car, it appears the seal for the sender unit is weeping a bit which is a lot better problem to have than needing a new gas tank. I check online for those. Nothing. Well I think its the same seal as most every Mopar tank used in the 70s so I should be OK when I ever get around to tackling that.
Of course no body panels available, or trim. As I mentioned in another thread, if I get in an accident I am screwed unless I could find some used parts or some unicorn NOS stuff.
The payoff is that it is cool to have something different in a showfield full of Chargers, Roadrunners, cudas and Challengers! The downside is you have to really work hard to find parts rather than just pull out the credit card and fill out an online order form and then have something at your door in a few days.
Re: sure buy a 80-83 cordoba/mirada they said [Re: Mastershake340] #3052405
06/22/22 12:53 PM
06/22/22 12:53 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Pretty sure I saved that old setup off my 82 Cordoba. If you decide you want to keep it original.
Re: sure buy a 80-83 cordoba/mirada they said [Re: theraif] #3052441
06/22/22 03:48 PM
06/22/22 03:48 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Wow, you almost had a free Carolina squat going there ... good you found it!
It takes gasoline to interest me.
Re: sure buy a 80-83 cordoba/mirada they said [Re: VL21] #3052475
06/22/22 05:54 PM
06/22/22 05:54 PM
Buckeye Lake
56_Royal_Lancer Offline
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
I have a non-Mopar I've owned for a long time (40 years as of June 20th). It is a car that has virtually no aftermarket support, so I have purchased 2 others over the years and cut them up for parts. I have complete quarters, a complete nose, basically every body panel and even a complete convertible top frame and all the trim. Whenever I came across a part for this car I would buy it and store it. When you "dare to be different" it's part of the deal. To me it's worth it. No '69 Camaro or '57 Chevy for me.
Good luck with your car, and a "tip of the hat" to everyone that goes through the hassles of keeping the rare ones on the road.
Re: sure buy a 80-83 cordoba/mirada they said [Re: 56_Royal_Lancer] #3052524
06/22/22 08:04 PM
06/22/22 08:04 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
One good thing about the late B's is that there's a fair number of parts that were used on the 71 up cars that will interchange, even better post-73. I think the aftermarket has to come on board making some things. Maybe I'm dreaming.
I'd help anyone I could find parts for the post 74 B's and the F/M/J cars . We have our network as we have to stick together.
Mastershake, as long as yours isn't a 79, the tank seal is the same. if not, I"ll get you one.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: sure buy a 80-83 cordoba/mirada they said [Re: larrymopar360] #3052538
06/22/22 08:24 PM
06/22/22 08:24 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Care to share that info?
Re: sure buy a 80-83 cordoba/mirada they said [Re: Magnumguy] #3052546
06/22/22 09:13 PM
06/22/22 09:13 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Thank you for the offer to help. I am looking for a decklid for my 79 diplomat coupe. Any help is appreciated.
Re: sure buy a 80-83 cordoba/mirada they said [Re: Magnumguy] #3052687
06/23/22 11:41 AM
06/23/22 11:41 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Check out Firm Feel website :
http://www.firmfeel.com/fmj_body_mopar_parts.html
Cheers,
Mark
Re: sure buy a 80-83 cordoba/mirada they said [Re: 56_Royal_Lancer] #3052735
06/23/22 03:01 PM
06/23/22 03:01 PM
moparx Offline
moparx  Offline
just like Royal above, when i see things i may need in the future for any of the rides here, i buy it. what i have found over the years though, if you have it on hand, you never need it. biggrin
that can be good or bad, depending on your storage set up.
yes, i "store" a lot of "stuff". laugh2
beer
Re: sure buy a 80-83 cordoba/mirada they said [Re: moparx] #3052830
06/23/22 09:41 PM
06/23/22 09:41 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
I can think of two hoods I could not give away 7 or so years ago, A flat 69 Dart hood with PRISTINE front trim, the other? 69 Charger. Both went to my scrap guy. At one point the hood trim for the dart was worth some $$ Now I see people looking for the flat hoods frown Both went to my scrap guy. I told him to hang onto the charger hood and he sold it a few years later for 150.00. ot sure what current market on that would be and probably don't want to know bawling
Current problem child is a BB 64 console shift 727 and it's later model brother (73 or 4) BB 727 that I really don't want to scrap. shruggy beer
Re: sure buy a 80-83 cordoba/mirada they said [Re: TJP] #3052946
06/24/22 11:42 AM
06/24/22 11:42 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
[q[/quote]
Current problem child is a BB 64 console shift 727 and it's later model brother (73 or 4) BB 727 that I really don't want to scrap. shruggy beer [/quote]
UGH! If you weren't so far away, I would be looking at that 73/74 unit...
Common sense is a flower that does not grow in everybody's garden
Re: sure buy a 80-83 cordoba/mirada they said [Re: Ron_M] #3052952
06/24/22 12:05 PM
06/24/22 12:05 PM
a12rag Offline
a12rag  Offline
Hey try any of the "special" 70's C body cars (Sport Fury S23, Sport Fury GT, 300Hurst) . . . no aftermarket parts, at all !! . . . well ok, there were stripe kits . . .lol . . . no body panels ! or interior parts ! . . . was amazed when I did the Sport Satellite, at ALL the parts available !! WOW !!!
Re: sure buy a 80-83 cordoba/mirada they said [Re: a12rag] #3053194
06/25/22 02:06 AM
06/25/22 02:06 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Try to find anything for '71-up B-body wagons or ANY C-body wagon. "Wagons are SO hot" Yeah, everyone EXCEPT these models..........
I can deal with no sheet metal, but the lack of ANY weather stripping is my biggest issue right now. Always CAREFULLY closing the doors and tailgate so I don't bust a window on bare metal........ mad
John
Re: sure buy a 80-83 cordoba/mirada they said [Re: SattyNoCar] #3053245
06/25/22 11:37 AM
06/25/22 11:37 AM
my own world
theraif Offline OP
theraif  Offline OP
my own world
iagree
Re: sure buy a 80-83 cordoba/mirada they said [Re: SattyNoCar] #3053415
06/26/22 07:23 AM
06/26/22 07:23 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Several places on line offer formed weather stripping material available by the foot. You choose the shape of the weather stripping you need by a profile picture of the actual weather stripping (or as close as possible) and buy however many feet of it you need. You use weather stripping glue (3 M stuff works better then the other stuff on the market) and super glue the square cut ends together to form the complete circle if you need that. Might not be the perfect replacement stuff, but at least you can save the glass and block off some wind draft.
If you guys really want a challenge, try buying anything for 40's Mopars.
Re: sure buy a 80-83 cordoba/mirada they said [Re: poorboy] #3053836
06/27/22 02:34 PM
06/27/22 02:34 PM
Buckeye Lake
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
If you guys really want a challenge, try buying anything for 40's Mopars. [/quote]
The guys with '57 Chevies will never feel the loneliness I felt building this thing:
Re: sure buy a 80-83 cordoba/mirada they said [Re: 56_Royal_Lancer] #3053889
06/27/22 05:08 PM
06/27/22 05:08 PM
a12rag Offline
a12rag  Offline
[/quote]
No doubt true . . . BUT . . . you have way cooler ride !!! . . .nice car !!!
Re: sure buy a 80-83 cordoba/mirada they said [Re: a12rag] #3053930
06/27/22 07:23 PM
06/27/22 07:23 PM
Buckeye Lake
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
Thanks! It's a 440/727/8 3/4 combination and everything had to be fabbed.
